Finned Pipe Trouble
Old   August 26, 2009, 11:07
Default Finned Pipe Trouble
Fabio
fabioxyz is on a distinguished road
Hi, I need to solve a trouble with cfx used to simulate an example of "fin pipe" as in figure below, where the lower face of pipe trasmit a heat power and where ther is a flow of water.
The blue zone is a water domain. If each single fin separates blue zone into multi-parts domain, as we see in figure,
the solver fails imediatly and providing this error message:
An error has occurred in cfx5solve: |
| Error interpolating results onto the new mesh: C:\Program |
| Files\Ansys Inc\v120\CFX\bin\winnt-amd64\solver-hpmpi.exe exited |
| with return code 1.
Otherwise if the fins are more little then pipe's height (as second figure) , domain is considered as a single part, and
the solver correctly runs.
Could you explain me the reason of that mistake?
ps for both geometry i have defined in cfx-pre the same elements:
  1. 1 fluid domain (1°geometry: nine parts not contiguous; 2°geometry one part)
  2. 1 solid domain
  3. One Boundary condition for water in flow
  4. One Boundary condition for water out flow
  5. Boundary condition for heat transfer from lower face of pipe
  6. interface from solid and liquid domains
Thanks
fabioxyz is offline   Reply With Quote
Old   August 26, 2009, 19:29
For the case with separate fluid domains, put a separate inlet and outlet boundary condition on each face. I am not sure that's the problem but its worth a try.
Old   August 27, 2009, 05:55
Fabio
yes, with that solution, i'm sure working fine, but i think that are another way (more quick) to set cfx-pre...don't u think so?
Old   August 27, 2009, 08:18
On the geometry you show it will only take a few minutes to set it up as I describe. How much quicker do you want? Are you going to spend days trying to speed the setup up by 5 minutes?
Old   August 27, 2009, 08:24
Fabio
yes yes, u are right, it'was only my curiosity
Old   August 28, 2009, 04:44
Default Simmilar problem
mistry
csmistry is on a distinguished road
Dear sir,
I am facing same problem for analysis of fluid flow with insert like for modeling i prepared one cylinder then i inserted a thin plate as you deed and then i cut that geometry.. it generates to parts for inlet i select to portions same way for outlet 2 portions and outer wall... means by putting this plate i am splitting the flow in two domains.... i am getting the same error as you are... return code 1.
please guide me what to do...
csmistry is offline   Reply With Quote
Old   August 28, 2009, 04:58
Fabio
as ghorrocks said me, try to create 2 equal boundary condition for Inlet and the same for out boundary condition. wait your news
Old   August 28, 2009, 07:41
Or to put it more clearly a boundary condition should not span multiple domains. Boundary conditions which span multiple parts of the same domain which are not connected (eg two fluid regions in one fluid domain with a solid region in between) should also have separate boundary conditions on each region.
Old   August 31, 2009, 03:20
Default solution
mistry
Yes, thank you sir. i spend hours to have solution and i got it..
thanks a lot
flow in perforated pipe distributor pertupd ANSYS 0 August 12, 2009 09:36
calculation of thrust thrugh a pipe with CD nozzle izhar Main CFD Forum 0 February 28, 2009 10:22
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 10:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
