FSI error????
Old   August 26, 2009, 02:53
Default FSI error????
hun
hung is on a distinguished road
FSI, transient, ANSYS12.
Ans.Core.Commands.UserReadableFailure: The CFX Solver for system Fluid Flow did not produce a results file. Detailed information can be found in the output file for the run, which can be viewed by selecting Display Monitors from the Solution cell.
at Ans.CFX.CFXCore.Data.CFXSolutionSource.HandleRunFa ilure(CommandContext context, String outFileName, String rawSolverOutput)
at Ans.CFX.CFXCore.Data.CFXSolutionSource.ReconnectRu n(CommandContext context, SolverBackgroundTask task)
at Ans.CFX.CFXCore.Data.CFXSolutionSource.RunSolver(C ommandContext context, Boolean forceResume)
at Ans.CFX.CFXCore.Data.CFXSolutionSource.Update(Comm andContext context)
at Ans.CFX.CFXCore.Commands.UpdateSolutionCommand.Exe cute(CommandContext context)
at Ans.Core.Commands.Concurrency.CommandWorkUnit.exec uteInContext(CommandContext subContext, IExecutionEngineCallback tracer)
at Ans.Core.Commands.Concurrency.BaseWorkUnit.doExecu te(IExecutionEngineCallback executionEngine, CommandContext subContext)
at Ans.Core.Commands.Concurrency.BaseWorkUnit.Execute (IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ans.Core.Commands.CommandFailedException: The CFX Solver for system Fluid Flow did not produce a results file. Detailed information can be found in the output file for the run, which can be viewed by selecting Display Monitors from the Solution cell.
Command: CFX.UpdateSolution(Container="Solution 2")
at Ans.Core.Commands.CommandAsyncResult.RethrowFailur eException()
at Ans.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
at Ans.Core.Commands.CommandAsyncResult.Wait()
at Ans.ProjectSchematic.Data.CellTemplateEntity.Updat e(CommandContext context, IProgressMonitor progressMonitor, DataContainerReference container, List`1 downstream)
at Ans.ProjectSchematic.Update.UpdateImpl.updateCell( CommandContext context, UpdateTask task)
at Ans.ProjectSchematic.Update.UpdateImpl.<>c__Displa yClass25.<updateCellAndDependencies>b__24()
at Ans.ProjectSchematic.Update.UpdateImpl.executeWith SelectedErrorBehaviour(Op op, UpdateTask associatedTask)
and then i check in the result display
| U-Mom | 1.40 | 1.6E-03 | 1.8E-02 | 5.5E-02 OK|
| V-Mom | 1.20 | 1.7E-03 | 2.2E-02 | 7.8E-02 OK|
| W-Mom | 0.90 | 1.1E-02 | 1.2E-01 | 1.2E-02 OK|
| P-Mass | 4.44 | 3.6E-02 | 4.3E-01 | 12.5 5.7E-02 OK|
| K-TurbKE | 0.46 | 5.0E-02 | 4.2E-01 | 5.5 2.4E-03 OK|
| E-Diss.K | 1.65 | 1.1E-01 | 1.7E+00 | 12.2 5.0E-06 OK|
| ERROR #002100061 has occurred in subroutine SERVE_CLIENTS. |
| Message: |
| The connection between this CFX process and an external process |
| has died unexpectedly. The following error was received: |
| External process : ANSYS |
| Error experienced : Read |
| ** This error is fatal: Terminating ANSYS CFX Solver execution ** |
| Please review the output, error and log files from both the CFX |
| and external processes to determine the cause of the error. |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
is there any idea what i should do in this case???
thanks in advance,
Hung
hung is offline   Reply With Quote
Old   August 26, 2009, 03:26
Lance
Lance is on a distinguished road
Seems like your Ansys Mechanical sovler crasched:
Lance is offline   Reply With Quote
Old   August 26, 2009, 03:50
hun
I have no ideas at all.
and then i changed something to run the simulation again.
| Z-Disp | 0.10 | 3.8E-06 | 1.7E-05 | 6.3 1.4E-02 OK| +----------------------+------+---------+---------+------------------+
| ERROR #002100011 has occurred in subroutine cVolSec. |
| Message: |
| A negative SECTOR volume has been detected. Execution will proceed |
| but this is a possible cause of robustness problems. |
| The location of the first negative volume is reported below. |
| Volume : -0.1713E-10 |
| This warning may be made fatal by setting the expert parameter |
| 'negative volume option = 1'. |
| ERROR #002100012 has occurred in subroutine cVolSec. |
| Message: |
| A negative ELEMENT volume has been detected. This is a fatal |
| error and execution will be terminated. The location of the first |
| Volume : -0.1870E-10 |
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| CFX encountered the error: |
| 0. A folded mesh has oc- |
| curred. This process will shut down as soon as possible. |
| Writing crash recovery file |
| Message: |
by the way, do you know what should i define in ANSYS MECHANICAL:
about the Analysis setting:
how to define: "auto time stepping" and "time step"
so the ANSYS can coupling with the CFX
now i set the "auto time stepping" off and time step is the time between each steps.
thanks,
Hung
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
