Temperature dependent thermal property in CFX
Old   August 21, 2009, 15:14
Default Temperature dependent thermal property in CFX
Subhadeep
Subhadeep is on a distinguished road
Hi
Trying to define a material in CFX pre with temperature dependent expression
This is what I entered :
2.9544 + 0.02*T [W m^-1 K^-1]
While running gives me error saying :
Error processing expression 'Thermal Conductivity'.
Error at position 17. Units [W m^-1 K^-1] are associated with an expression that is not dimensionless.
What should the correct expression be? Should I take out
[W m^-1 K^-1]
Thanks ....
Subhadeep is offline   Reply With Quote
Old   August 21, 2009, 15:56
NickFL is on a distinguished road
The problem is that T has a units associated with it. What you need to do is make sure the final result ends with a [W m^-1 K^-1]. So we would have to change it to:
2.9544 [W m^-1 K^-1] + 0.02 [W m^-1 K^-2] * T
Notice the Kelvin unit on T will cancel the one associated with the 0.02 providing the correct units. Let me know if you need further explaination.
NickFL is offline   Reply With Quote
Old   August 21, 2009, 16:07
Default Thanks
Subhadeep
That helped ...
After reading the messages I thought on similar lines but used it like this and that still gave me an error :
2.9544 [W m^-1 K^-1] + 0.02*T [W m^-1 K^-2]
Old   August 21, 2009, 16:29
Needs to be exactly as I have it. Again the units of [W m^-1 K^-2] must be associated with 0.02 and not as you have it where CFX is trying to associate T with [W m^-1 K^-2] when it already has units of [K].
Old   August 22, 2009, 21:21
Smile
Jack
rogbrito is an unknown quantity at this point
Hi Sir,
let me explaining ! For example, for the heat flux boundary condition, you have to build a variable called Fluxoa, like this (where t is time in [s], and Fluxoa is a heat flux in [W m^-2]:
Fluxoa
(B*(19453.29701*(t/A)^3.07678)/(4.73947^3.07678+(t/A)^3.07678))
A 1.0 [s]
B 1.0 [W m^-2]
So, the Fluxoa variable will have the [W m^-2] final heat flux unit !
with kind regards,
Rogerio .
Originally Posted by Subhadeep View Post
Hi
[W m^-1 K^-1]
Thanks ....
rogbrito is offline   Reply With Quote
Old   March 22, 2012, 02:52
mactech001 is on a distinguished road
will this be also valid if i were to define a temperature dependent body load please?
Thank you for your kind attention.
Kind regards,
mactech001
Currently using: ANSYS v13
mactech001 is offline   Reply With Quote
units
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 18:31
Problems in CFX 5.5.1 Sulviyanti CFX 6 February 7, 2003 17:46
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
