ERROR #001100279 has occurred in subroutine ErrAction. |
August 19, 2009, 01:23 |
Thanathat
Rep Power: 17 |
Hi All
I have the error message as below any body help please.... My Problem have 8 CPUs with motor design anlso have a area for rotating but for the first iteration have error as belo. ================================================== ==================== OUTER LOOP ITERATION = 1 CPU SECONDS = 1.054E+02 ---------------------------------------------------------------------- | Equation | Rate | RMS Res | Max Res | Linear Solution | +----------------------+------+---------+---------+------------------+ Parallel run: Received message from slave ----------------------------------------- Slave partition : 8 Slave routine : ErrAction Master location : RCVBUF,MSGTAG=1012 Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Floating point exception: Invalid number | | | | | | | | | | | +--------------------------------------------------------------------+ Parallel run: Received message from slave ----------------------------------------- Slave partition : 8 Slave routine : ErrAction Master location : RCVBUF,MSGTAG=1012 Message label : 001100279 Message follows below - : +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine C_FPX_HANDLER: | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver exited with return code 1. No results file | | has been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | D:\Mongkol\Motor\Motor_1_002: | | | | mon | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. |
August 19, 2009, 08:56 |
Rep Power: 144 |
This looks a little unusual but I suspect the root cause is merely a rapidly diverging simulation. Check the simulation is correctly setup and improve its stability and it should start up. Glenn |
ERROR #001100279 in subroutine ErrAction | Stephan | CFX | 18 | October 14, 2019 18:15 |
ERROR #002100013 has occurred in subroutine Chk_Sp | Forrest | CFX | 4 | August 2, 2017 19:59 |
ERROR #001100279 has occurred in subroutine ErrAct | Yijin Li | CFX | 1 | December 1, 2008 17:21 |
ERROR #001100279 has occurred in subroutine ErrAct | Mohamed Musthafa | CFX | 0 | September 29, 2005 09:41 |
ERROR #001100279 has occurred in subroutine ErrAct | Carl | CFX | 2 | July 16, 2005 15:39 |
