CUDA with CFX
Old   August 18, 2009, 15:31
Default CUDA with CFX
Juan Martín Catelén
jmcatelen is on a distinguished road
Does anyone know if it's possible to use CUDA with CFX? I imagine Glenn can give me an answer.
jmcatelen is offline   Reply With Quote
Old   August 18, 2009, 19:42
My fame precedes me?
CFX cannot run under CUDA. The solver needs to be totally rewritten to use the system and that is a major task. I remember somebody mentioning that ANSYS is doing a preliminary investigation of CUDA to establish its feasibility but it was stressed that this was preliminary and a release of CFX on CUDA was along way off - if it gets released at all.
The CUDA system is not ideal for CFX. CFX, being an implicit solver runs best on a relatively small number of powerful CPUs as the simulation time is used constructing and solving a large matrix. CUDA works far better on explicit numerics where inter-node communications are much reduced as this suits the huge number of lower power CPUs in the CUDA system.
Also don't forget CFX in parallel is licensed per process. If you are paying for 100+ processes (serious dollars) there is no point running it on a computer worth only a few thousand dollars. A compute cluster of more traditional machines will cost more but perform far better and give you a much better return on your software investment.
So in short I don't think CUDA is going to help CFX much. There are a small number of explicit CFD codes out there and they will get a huge performance boost on this type of system, eg the Fluent density based solver or Powerflow - they are the ones to use on CUDA.
Glenn
Old   August 26, 2009, 23:29
Default OpenFoam
Mauro
mjatalla is on a distinguished road
Maybe this is not the right thread, but seeing it made me wonder whether OpenFoam would benefit from a GPU implementation. Thoughts? Thanks in advance.
mjatalla is offline   Reply With Quote
Old   August 26, 2009, 23:36
That question would be better posted on the openfoam forum. Also note the solver needs to be rewritten on the CUDA system. Not just compiled on the CUDA system, totally rewritten to take advantage of the CUDA system. This is no small issue!
But in general, the simulation software which will run best on CUDA will be explicit numerics.
Old   August 27, 2009, 09:42
Default Cuda
Juan Martín Catelén
Well, thanks for both anwers. I'll keep insisting to see if a cluster can be bought.
Bye.
Old   August 27, 2009, 20:33
Sounds fun - but don't expect to run CFX on it. It has not been compiled to run on it and won't be for a long time yet.
Old   August 28, 2009, 18:01
Default Thanks
Mauro
Thanks for the quick reply!
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
Importing solutions in CFX. Alphonso CFX 1 August 1, 2008 15:01
PhD using CFX Rui CFX 9 May 28, 2007 06:59
CFX 10 VS CFX 11 for combustion Jonathan Lemay CFX 2 May 9, 2007 12:58
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
