Gravity effect
Old   August 18, 2009, 10:22
Default Gravity effect
Mario Tremblay
Mario is on a distinguished road
I am trying to simulate a return line by gravity. I want to know the maximum flow that can pass trought this line. I modelised the return line. In the two extremity, I put en opening pressure. Than, I set the gravity Y to 9,81m/s^2.
But the result are incoerent. The velocity flow is to low. Maybe I did something wrong. Can you tell me an other way to simulate my return line.
Tanks
Mario is offline   Reply With Quote
Old   August 18, 2009, 19:14
Camilo Costa
camilo_costa is on a distinguished road
Make sure that your reference density is correct!! If your reference density is correct try input a 0 Pa for your reference atmospheric pressure inside your domain!!
camilo_costa is offline   Reply With Quote
Old   August 19, 2009, 09:45
Mario Tremblay
Tanks for your answer,
I try to put my reference pressure to 0Pa. I also put boath end of te return line to openning and 0Pa.
The result are still incoerent.
Maybe I did not put my gravity at the wright place.
Actualy à set the Buoyancy to Buoyant. Than I set gravity Y Dirn. to 9.81m/s^2.
Gravity X and Z Dirn. is set to 0.
Old   August 20, 2009, 16:48
Mario Tremblay
I try a few other thing, but I still have an incoerent résult. To vérified my analisys, I modelise a srtait pipe so it is easy to compare with hand calculs.
If someone have alerady done the same analysis as my, I would be happy to know how you have done.
Sory for my writing mistake, english is not my first language.
tanks
Old   August 20, 2009, 17:31
Default def file
Camilo Costa
If you send the yourfile.def for i analyse the problem will be more easy to verify the problem!!
Regards!!
Old   August 20, 2009, 19:00
BGK
BGK
BGK is on a distinguished road
Hi Mario,
if your system is in "normal position", ie, the gravity vector cause a force in the negative Y direction, your component must be defined "Gravity Y=-9.81". Or your can use the variable "g" (recognized as the normal gravity >> "Gravity Y=-g".)
BGK is offline   Reply With Quote
Old   August 21, 2009, 08:56
Mario Tremblay
Can I send you my file by e-mail??
If not where I can put my *.def file to give it to you.
Old   August 21, 2009, 09:13
Mario Tremblay
Great
I think I found my mistake,
It was the boyancy réference température that was not the wright one. The température was to low.
Old   August 21, 2009, 10:30
Camilo Costa
No nothing!!
Gravity Effect.... Dev FLUENT 1 May 29, 2015 12:06
help!! Question about activating gravity mahe Phoenics 0 June 7, 2008 06:03
Gravity effect in Fluent chouki FLUENT 1 August 7, 2007 06:54
GRAVITY EFFECT IN CFX-5.5 alexander CFX 4 September 27, 2002 03:15
On gravity modelling... Drona CFX 7 November 22, 2001 11:28
