August 18, 2009, 04:55 |
Trying to stop CFX running mannually
Rep Power: 17 |
Hello to everybody,
I have been running a simulation with CFX 11 for one week and, for some reason I donīt know, I cannot access to CFX Post to save the results and stop the simulation but I know itīs still running. I would like to know if there is any way to stop the running without loosing the results. Perhaps killing it directly from DOS? Thank you in advance. |
August 18, 2009, 08:05 |
Martin Heiser
Rep Power: 17 |
You can use the CFX command cfx5stop to stop the solver after the current iteration using:
cfx5stop.exe -dir <directory_path_where_solver_runs> The path name of the current solver run usually looks like Name-of-Simulation_<Number-of-Run>.dir |
August 18, 2009, 08:07 |
SanS
Rep Power: 17 |
Hi, Check the help files for stopping a run from the command line. Your can also put a stp file in the wrking dir.
-Sans |
August 18, 2009, 08:56 |
Rep Power: 17 |
Thank you, Martin.
When I am in the directory path I write: cfx5stop.exe -dir Nameofsimulation_numberofrun.dir ŋIs it correct? |
August 18, 2009, 09:07 |
Martin Heiser
Rep Power: 17 |
You don't have to be in the directory. But better give the full path as argument to the -dir option...just in case there's another solver running
August 18, 2009, 09:41 |
Rep Power: 17 |
Martin, thanks a lot. Your information was really helpful.
August 26, 2010, 14:29 |
STP file
Rep Power: 16 |
What is an stp file like - I would like to use them to stop my runs?
August 26, 2010, 17:12 |
Rep Power: 21 |
Create a file named "stp" inside the run directory (the one ending in .dir). Nothing in the file, no file extension, just name it "stp" and that's it.
August 27, 2010, 12:00 |
#9 |
Rep Power: 16 |
Thanks that did the trick.
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Small time step and CFX solver crashing | Vanessa | CFX | 2 | June 21, 2006 10:18 |
Problem in running CFX in red hat linux | Q | CFX | 0 | March 30, 2006 10:11 |
Problems on running cfx in parallel | Nan | CFX | 1 | March 29, 2006 05:10 |
CFX 10 in CFX 5.7 | panneerselvam.R | CFX | 6 | February 6, 2006 04:56 |
