Multi-Stage Compressor
Old   August 18, 2009, 02:58
Red face Multi-Stage Compressor
Arda Ersan
cfdman is on a distinguished road
Hey All,
There is a compressor which working in vacuum conditions. Also take N2 from 0.01 [mbar] (this is absolute pressure) and i want to model this in CFX.
My boundary conditions are;
inlet=0.01 mbar static pressure
outlet= 0.0125 kg/s
Pref= 0 [atm]
But pressure contours on CFX-Post i see negative pressure values about -2.5 [bar] this is physically not valid. Because environment is 0.01 [mbar] absolute pressure.
Does anyone have a suggestion for me?
Thanx
cfdman is offline   Reply With Quote
Old   August 18, 2009, 19:20
I assume you are running a compressible flow. I can't see how you would get negative absolute pressures as the density is undefined and therefore the solver would diverge. Are you sure you have your reference pressure set correctly?
Glenn
compressor, vacuum
Rotor 67 full compressor geometry jf Main CFD Forum 3 January 28, 2024 06:14
Echardt compressor Abdul Nassar FLUENT 0 November 2, 2005 16:00
Stage Interface Without Frame Change Vikram CFX 2 October 21, 2005 05:55
How to mesh structured grid of a compressor stage ann FLUENT 2 January 4, 2003 23:29
CFD Problem: volumetric compressor Gabriele Velenich Main CFD Forum 2 July 2, 2001 09:15
