cfx12 x64 meshing: pc has 4 core but only 1 core working for the mesh? why?
Old   August 15, 2009, 23:41
Default cfx12 x64 meshing: pc has 4 core but only 1 core working for the mesh? why?
lee ruoyun
leeruoyun is on a distinguished road
previously, cfx11, when meshing on 32bit with dual cpu, both 2 cpu working HARD on the mesh....
why 64bit with CFX12 cannot mesh parallel ?
thanks for advices !
leeruoyun is offline   Reply With Quote
Old   March 17, 2010, 22:18
nazareno mancinelli
yochule is on a distinguished road
hello leeruoyun, i'm having the same question....
i'm using cfx12.0 with an amd phenomX4, but when i put cfx meshing i note only one core is used.
can you post your solution if you have?
thanks!
yochule is offline   Reply With Quote
Old   March 23, 2010, 13:37
Dmitry Volkind
dvolkind is on a distinguished road
Hello everybody!
I'm probably too late, but here is a tip if not tried yet. While in cfx-mesh use the outline:
Options->Volume Meshing->Parallel Advancing Front, then set the appropriate number of partitions. Done successfully on 4 different machines, both 32 and 64-bit.
Hope, I've been helpful.
PS That doesn't work with Extruded 2D Mesh.
dvolkind is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Meshing - Nested mesh block Mic FLOW-3D 6 February 17, 2009 10:50
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
