how to find property for compressible flow
Old   August 1, 2009, 17:24
Default how to find property for compressible flow
jai
jaikrishna
jai is on a distinguished road
as of now i assumed that my flow is incompressible and ran the problem.
I'm simulating turbo machine problem.
i would like to simulate compressible(real) model in my problem.
I'm simulating turbine problem. so pressure, temperature and density at inlet to outlet vary. i know the pressure and temperature at in & outlet. using some general relationship i could find the density at in & outlet.
how do i find the varying property(density) of fluid through out the domain?
In cfx solver we are giving property of fluid with respect to standard temperature (ex:25°C).
if my problem is about 500°c means solver may automatically calculate the property for this temperature?
if it won't means how or where do i get it?
jai is offline   Reply With Quote
Old   August 2, 2009, 19:54
Sounds like you should look at the tutorial titled "Flow in an axial rotor-stator". This will show how this sort of simulation should be set up. While you are reading have a look in the best practices guide for turbomachinery, also in the documentation.
Old   August 3, 2009, 22:09
Bharath kumar
bharath is on a distinguished road
you have to use CEL function to vary the fluid property.think first is it needed for your problem?
bharath is offline   Reply With Quote
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
FFT on flow field to find peaks? CFDtoy Main CFD Forum 17 June 7, 2011 07:34
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
About the invisd flow around an airfoil maximus Main CFD Forum 1 July 16, 2005 16:04
Help: Poiseulle flow benchmariking Mohammad Kermani Main CFD Forum 1 November 12, 1999 17:15
