July 28, 2009, 09:04 |
Question about CFX-Pre Variables
Rep Power: 17 |
Hi,EVERYONE,
I am simulating Droplet-Gas two-phase flow, and I want to use the impact angle of droplets on the wall to compute other variable, But I can not find this variable in CFX-Pre , COULD someone give me a help? Thanks! |
July 29, 2009, 08:13 |
Rep Power: 21 |
I assume this is Eulerian 2 phase flow. Perhaps you could create a boundary-only Additional Variable, setting it to a function of the phase Velocity vector and the surface normal vector ( i think that variable is called "Normal Direction X | Y | Z"). I think boundary-only AV's are a CCL-only feature (I could be wrong here) - if so, just create a normal algebraic AV, then add the Boundary Only parameter to the CCL. You'll need to check the RULES files in the <install root>/<version>/CFX/etc directory to see exactly the correct syntax.
How to set up a CFX Pre? | winglet | CFX | 4 | July 2, 2009 13:46 |
CFX Pre Error - has anyone seen this? | Jenny | CFX | 1 | January 29, 2009 03:38 |
CFX 10 question | DAK565656 | CFX | 0 | August 6, 2007 01:06 |
simple question about ICEM CFX | sleepinglily | CFX | 0 | October 27, 2004 14:15 |
Question about meshing / solution scheme of CFX | Coriolius | CFX | 8 | August 1, 2004 19:39 |
