supersonic two phase inlet
Old   July 24, 2009, 06:17
Default supersonic two phase inlet
kuhbuh is on a distinguished road
I'm modeling compressible high-speed two-phase flow in CFX. My inlet is supersonic based on the two-phase sound speed. But, when I consider the individual sound speed of each phase at the given pressure and temperature, both phases are subsonic. Which criteria does CFX use? I believe it's the indivindual sound speed because of "mixed" options in CFX but I want to confirm it. Please enlighten me. Thanks a lot!
kuhbuh is offline   Reply With Quote
Old   July 28, 2009, 11:07
guys help me with this question PLEASE!!! Thanks a lot!
Old   July 28, 2009, 21:21
This is quite a specialised question so it does not surprise me you have not got an answer. It is not in my area of expertise so I would be reading the documentation and not speaking from experience. You will have to read the documentation and work it out, or contact CFX support for more detailed assistance.
Old   July 29, 2009, 02:13
Thank you so much Sir Glenn!
I've read the documentation several times but I could not find specific explanation for this. I've just thought that having an "inlet(mixed subsonic-supersonic)" option for two-phase model in CFX means that the criteria of being "supersonic" or "subsonic" is on per phase basis. Our support is in Japanese that's why I usually rely on this forum. Thanks again sir!!!
Old   July 29, 2009, 02:18
No, you misunderstand the mixed inlet. It means some regions of the inlet can be subsonic and some supersonic. It does not mean that at a particular point the flow can be both sub and super sonic for different phases.
In fact I think the sub/super sonic at a point you mention is impossible as the pressure field is shared between phases so pressure waves must propagate at the same speed for all phases. So the speed of sound must be the multiphase value.
Old   July 29, 2009, 02:48
Sir Glenn,
Thank you so much!!!
I missed that concept about sharing a common pressure field. You've explained it very well. Thanks again!
supersonic, two phase
subsonic inlet or supersonic inlet? mali CFX 0 November 28, 2008 21:57
B.C. for Supersonic inlet ? jakjak CFX 1 December 3, 2007 16:27
supersonic inlet problem! gopal Main CFD Forum 2 May 2, 2007 02:38
How much the value of secondary phase at the inlet KBS FLUENT 2 May 31, 2006 11:18
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
