Tutorial -6 sUPERSONIC OPTION
Old   July 23, 2009, 01:31
Angry Tutorial -6 sUPERSONIC OPTION
mistry
csmistry is on a distinguished road
For boundary condition at inlet in flow option i am enable to get SUPERSONIC FLOW...
ONLY OPTION AVALABLE IS "SUBSONIC FLOW" .... WHAT TO DO..
csmistry is offline   Reply With Quote
Old   July 23, 2009, 04:24
Timon is on a distinguished road
You have to explain your problem with more detail to get proper help.
Most likely, your setting up an incompressible simulation (e.g. air at 25 deg), for which supersonic boundary are naturally not available. If so, change your fluid material definition (to air ideal gas for example).
Timon is offline   Reply With Quote
Old   July 24, 2009, 03:53
Default transient analysis of covergent nozzle
mistry
Sir,
i want to do transient analysis of convergent nozzle.
For boundary conditions:
Fluid : ideal air.
Inlet: subsonic and supersonic conditions, i know pressure at inlet,velocity also. for steady state analysis i want to vary pressure.
outlet: pressure ( I WANT TO SPECIFY- how to specify). relative pressure i take 0 bar
wall condition: no slip
turbulent model :K-Epsilon
for transient condition:
refering to Fluent tutorial:
Pexit(t)=0.12sin(wt)+Pexit
how to specify time step
how do i proceed?
I tried with steady state specifying mass flowrate at inlet and pressure at exit but i is not converging.i think by boundary conditions are wrong...
please suggest me
Old   July 27, 2009, 18:25
Zvika
benadam10 is on a distinguished road
Hi chmistry,
try to switch default domain->fluid models tab->heat tranfer->total energy
The supersonic inlet will be available.
adam
benadam10 is offline   Reply With Quote
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
about compresive phase James CFX 10 September 12, 2006 04:16
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
