Convergence problem with thermal phase change model under low velocity conditions
Old   July 21, 2009, 12:21
Default Convergence problem with thermal phase change model under low velocity conditions
Piti
pitisrisuk is on a distinguished road
I have a tutorial from Ansys about how to use thermal phase change model (Multiphase Workshop 7). So I set my problem very similar to what are in the example: inhomogeneous multiphase flow (water and water vapor), k-epsilon with medium intensity. When I have a velocity inlet of 0.5 m/s, convergence is beautiful and mass imbalances are excellent. However, when I lower the inlet velocity to 0.05 m/s, problem arises and this is the only parameter I change. It doesn't converge at all, and mass imbalances go crazy. I checked the Re number for velocity of 0.05 m/s, it is almost 10000, which shows that it is a turbulent flow. I try k-omega model, but it doesn't help. Any suggestions?
pitisrisuk is offline   Reply With Quote
CONVERGENCE PROBLEM - oil boiler MM FLUENT 1 February 15, 2007 06:24
Settling Velocity - FLUENT Discrete Phase Model Lily FLUENT 2 March 6, 2002 22:44
Help - Two Phase Flow - Convergence Problem R.Sureshkumar Main CFD Forum 1 February 22, 2000 04:24
A problem about setting boundary conditions lyang Main CFD Forum 0 September 19, 1999 19:29
Geometry setup for phase change problem Fred G. Kang Main CFD Forum 1 October 14, 1998 12:41
