July 17, 2009, 10:37 |
CFX error, "Floating point exception"
tato
Rep Power: 17 |
I am trying to model wind turbine in CFX. During the run (first iteration), i am getting the error message:
Floating Point Exception: Overflow What's wrong with my simulation??? Thank you |
July 17, 2009, 11:42 |
its an error
check your mesh again, this kind of error usually comes when during Pre-processing in CFX some wrong initial parameters are used....
Can you please give me more information about your work. Will see to it... regards, Tushar |
July 18, 2009, 03:03 |
Rep Power: 17 |
hi:
i think think this error is due to the memory,,,try 64bit ansys... |
July 18, 2009, 08:41 |
smn is some what right....one of the reason i guess would be
smn is some what right....one of the reason i guess would be, you might have allocated less memory... Give it a parallel run, allocate more memory too... your problem will be solved definately....
regards.. |
July 20, 2009, 03:18 |
Rep Power: 144 |
Sorry but nobody has posted the correct answer here yet. Floating point exceptions are signs that your simulation has diverged big-time. Either the physics is wrong or the numerics are wildly unstable.
It has nothing to do with 32/64 bit. Glenn Horrocks |
July 20, 2009, 11:05 |
tato
Rep Power: 17 |
Thank you Mr. Glenn Horrocks, so what should I do?
July 20, 2009, 14:10 |
Bharath kumar
Rep Power: 17 |
hi,
Either your mesh quality or the physics must be wrong.please check it |
July 20, 2009, 19:48 |
Rep Power: 144 |
First you should check that the physics of your simulation are correct. It is common to fail to get convergence on something which is not physically possible. After that is OK and you still have convergence problems then you should look into numerical reasons for the divergence. Read the documentation about "obtaining convergence". Mesh quality is one issue but there are many others. Glenn Horrocks |
July 23, 2009, 08:58 |
#9 |
tato
Rep Power: 17 |
ok, thanks all
CFX error, Floating point exception | Riyaz | CFX | 4 | May 18, 2010 02:13 |
Electronics Enclosure Analysis with CFX | Simulation Engineer | CFX | 1 | April 22, 2009 12:08 |
CFX 10's solutions differ from CFX 5.7's | Atit Koonsrisuk | CFX | 4 | July 26, 2006 12:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 05:07 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
