CEL for coefficiency
Old   July 7, 2009, 22:39
Smile CEL for coefficiency
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
Hi everyone
recently i try to modify the coefficient of models in the ANSYS CFX 11.0 by using the CEL to apply some modfication.but i have got expression errors as:
Expression Error in object "/FLOW/DOMAINitzDaily/FLUID MODELS/TURBULENCE MODEL/K EPSILON REGIME/OMEGA COEFFICIENTS" :
Parameter 'Beta Coefficient' in object '/FLOW/DOMAINitzDaily/FLUID MODELS/TURBULENCE MODEL/K EPSILON REGIME/OMEGA COEFFICIENTS' appears to have been assigned an expression value 'BetaKE'. This parameter may take only purely numeric values.
the BetaKE is an alternative for standard value of 0.075 for beta value in kEpsilon regime in SST model. it is a defined as :
BetaKE=0.075*F4
where:
F4=1/(1+3.6*Ri )
Ri=Vorticity in Stn Frame /Shear Strain Rate *(Vorticity in Stn Frame /Shear Strain Rate-1)
i don`t know what is wrong with it.
can anyone give me some advices?
thanks!
yours wayne
waynezw0618 is offline   Reply With Quote
Old   July 8, 2009, 03:43
ckleanth's Avatar
George
ckleanth is on a distinguished road
when cfx is complaining that a parameter may take only purely numeric values that means because of solver stability the programmers have disabled that coefficient to depend on variables
I'm not sure how you will do what you want but it looks to me as you're heading on fortran subroutines
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
cel
Angle variable under CEL. Gloria Gaynor CFX 11 November 26, 2012 07:29
junction box routine and CEL function bornspur CFX 2 February 3, 2009 03:24
Using CEL Funtion jaiye CFX 6 August 18, 2008 20:37
Rotate node via cel Elian81 CFX 2 September 25, 2007 06:31
how to load a cel file? ioana CFX 11 June 24, 2004 20:42
