July 4, 2009, 01:28 |
Finned tube Modelling
mistry
Rep Power: 17 |
Friends
i always do experiment for different problems.. Presently i am doing analysis of finned tube. Problems are: 1. How to model gas passage, solid(tube ) and water passage(inside) tube. i used the concept of frozen option for gas passage and neglected tube surface second domain i select for water that is soli (add material-extrude) but... in case if i want all the 3 domains seperate what steps i follow...!! 2. for meshing i choose regions like GSAINLET,GASOUTLET,WATERIN,WATEROUT,INSIDE TUBE-SYM-1 SYM2,OUTERWALLGAS AND OUTERWALL GAS, FOR FINNED SURFACE I CHOOSE TWO WALLS OPTION... AM I GOING RIGHT .. |
July 5, 2009, 07:49 |
Rep Power: 144 |
I don't understand what you are asking.
Your first question is weird. This sounds like a straightforward CHT simulation and you just model the air, liquid and solid as different domains. Forget about frozen options. A some tutorials on CHT simulations. (CHT = Conjugate heat transfer,ie heat transfer with both solid and fluid domains included) I don't know what you mean by your second question. Are you referring to the interface between solid and fluid domains? That is just a domain interface, either 1to1 or GGI. Glenn Horrocks |
HLL Riemann Shock Tube Matlab Problem | Luke F | Main CFD Forum | 2 | May 20, 2016 03:10 |
What is best mesh for cylinder tube? | olivia | FLUENT | 7 | January 16, 2014 06:55 |
Modelling a Shock Tube | James | FLUENT | 2 | July 21, 2004 11:42 |
BC at the inlet of a tube | Jackie | Main CFD Forum | 11 | July 29, 2003 12:57 |
Tube bank | M. long | FLUENT | 2 | April 26, 2000 09:16 |
