how to plot relative velocity on a plane in POST CFX |
July 2, 2009, 22:18 |
harry
Rep Power: 17 |
In my case, a water filled cylindrical domain and its surrounding surface was setup as wall, which rotates at a certain speed, my question is how I can plot the velocity profile(radial, tangential, axial component) relative to the wall in the chart viewer. Can anyone help me with it please?thanks. Harry |
July 3, 2009, 07:32 |
Rep Power: 144 |
I assume you did not use a rotating frame of reference - if you did you will have variables in both the stationary and rotating frame of reference in the output file by default. If it is a stationary frame of reference simulation you will have to generate the rotating frame of reference by generating a vector field (in the variables tab) which is the velocity in the stationary frame of reference plus the component to convert it to the rotating frame. This should be simply r x omega (where "x" means the vector cross product) Glenn Horrocks |
July 4, 2009, 04:48 |
harry
Rep Power: 17 |
HI, Glenn,
Thanks for your reply. Could you please tell me how to specify a rotating frame of reference in Pre-CFX? I tried to find it in tutorial, but it didn't help me a lot.Thanks in advance. |
July 4, 2009, 08:20 |
harry
Rep Power: 17 |
Hi Glenn,
Do you use domain motion in the basic setting tab of domain details in PRE CFX to specify rotating frame of reference(RFR)? I tried it, but I didn't find the variables of velocity in both stationary and rotating frame of reference in the variable tab in POST CFX. Could you please help me with it? Thanks. |
July 5, 2009, 07:39 |
Rep Power: 144 |
Do the rotor/stator example in the tutorials. It uses a RFR. Also note RFR is a license option which is not included in the basic CFX package. If you can't see it then you might not have that license option. Glenn Horrocks |
July 5, 2009, 12:21 |
harry
Rep Power: 17 |
Hi Glenn,
Thanks, I got it. By the way, do you know how to express vector cross product in CFX? Thanks. Harry |
July 5, 2009, 20:26 |
Rep Power: 144 |
In what context? The CEL has a cross product function (I think) or you can write it out in full as a CEL expression. Is this what you mean?
Glenn Horrocks |
July 6, 2009, 01:45 |
harry
Rep Power: 17 |
Hi Glenn,
Yes, that's it. But I didn't find vector cross product function in CEL, maybe it doesn't support vector arithmetic. I gotta to write it out. I'm trying to generate the rotating frame of reference by generating a vector field using my current simulations with stationary frame of reference. And this requires to use cross product. Do I need fortran to write it, any good suggestions? thanks. |
July 6, 2009, 02:24 |
#9 |
Rep Power: 144 |
CEL does not support vector variables, so make 3 CEL variables representing each component of the vector variable and then write out the cross product in terms of the components. A little messy but still pretty easy. Glenn Horrocks |
Transient animation performance in CFX 5.5 POST | Sjoerd Romkes | CFX | 8 | February 5, 2013 15:53 |
how to define pressure drop with CFX post | alex | CFX | 0 | September 20, 2007 18:31 |
Need help: Symmetry in CFX Post | Tran | CFX | 0 | September 17, 2007 22:00 |
Chart Generation in CFX Post | Vadim Baines-Jones | CFX | 2 | August 28, 2007 10:14 |
Relative velocity errors in cylindrical coords? | John | FLUENT | 0 | April 5, 2000 08:46 |
