general momentum source/hydraulic pressure jump/positive displacement machine |
June 28, 2009, 22:30 |
George
Rep Power: 18 |
I need some help in setting up a momentum source. I want to model an internal flow system that contains throttles and a positive
displacement machine. I want to see the effects of the positive displacement machine in the system, however I'm not interested on modeling the actual machine in 3D but a reduced mathematical model. I have the machine performance curves (speed, pressure ratio, volume flowrate, icentropic efficiency etc. Therefore I have created a general momentum source with a simple array that relates dp with flowrate for testing. As for BC inlet is relative pressure 0 [Pa] and outlet's velocity 5 [m/s] (will be massflow later to match the real problem setup but should be ok for now) FUNCTION: DpQ Argument Units = [Pa] Option = Interpolation Profile Function = Off Result Units = [m^3/s] INTERPOLATION DATA: Data Pairs = 0,0.025,500,0.05,1000,0.075 Extend Max = On Extend Min = On Option = One Dimensional END END #density = 1.284 [kg/m^3] #duct area = 0.05 [m^2] Pin = massFlowAve(p)@F91.89 2 Pout = massFlowAve(p)@F96.89 2 deltaP = abs(Pout-Pin) velocity = volflow/area@F96.89 2 volflow = DpQ(VardeltaP) #the variable VardeltaP is the algebraic expression deltaP scoef5 = -10e5 [kg m^-3 s^-1] svalue5x = scoef5 * (Velocity u - 0[m/s]) svalue5y = scoef5 * (Velocity v - 1[m/s]) svalue5z = scoef5 * (Velocity w - 0[m/s]) When I use the above basic source definition I can get the thing to converge with the specified velocity in the defined subdomain but when I use the equations below there are many issues: scoef5b = Density * volflow / volume()@B89 2 svalue5bx = scoef5b * (Velocity u - 0[m/s]) svalue5by = scoef5b * (Velocity v - velocity) svalue5bz = scoef5b * (Velocity w - 0[m/s]) a) for example cfx-post wont let me evaluate the velocity and volflow scalars so I dont know if my coefficient is calculated correctly. b) the problem converges but velocity has the value from the outlet boundary and pressure's are..... well wrong IN = -1.655e+01 [Pa] OUT= -1.547e+02 [Pa] dp across subdomain = -1.381e+02 [Pa] c) am I doing something wrong with my problem approach? I would appreciate any comments especially if the source coefficient is properly defined and if the expression volflow = DpQ(VardeltaP) is correct. many thanks
Top 4 tips 1. Knowledge is everything and Ignorance is dangerous. 2. Understand your limitations and try to eliminate them. 3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window. 4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials |
June 28, 2009, 23:55 |
Rep Power: 144 |
I would not use "velocity" as a CEL variable. It might get corrupted with the internal velocity variable. Use a different variable name. Glenn Horrocks |
June 29, 2009, 06:09 |
#3 | |
George
Rep Power: 18 |
However in cfx-post I do get the follwing error "The following unrecognised name was referenced: DpQ." thats the only bit that I'm unsure, the definition of the volflow expression as the function calculates at the pressure diferential at the inlet and outlet of the subdomain and then it should look up the pressure diferential from the array and output the volume flowrate. I attach the full ccl if anyone has the time to check and comment
June 29, 2009, 19:30 |
Rep Power: 144 |
Some issues I can see: You refer to "Density" in scoef5b. This is not defined. You define velocityx = volflow/area@F96.89 2. It should be area()@F96.89 2 You have no materials defined. Did you snip that out of the CCL? You need to have some materials defined. Glenn Horrocks |
June 29, 2009, 19:35 |
George
Rep Power: 18 |
materials is the stanadrd air @ 25 [C] mate (was a bit lazy ) I just copy paste the expression ccl code and forgot materials but use the standard ones for the example
Density is the variable name for density of the fluid m8 EDIT: yes stupid of me density but where its located thanks I got it now just checking the area()@
June 29, 2009, 19:57 |
George
Rep Power: 18 |
fixed the mistakes and cfx finds a solution but I still get still wrong results which means there is still something else wrong as I still get the "The following unrecognised name was referenced: DpQ." in cfx post
The 1D array is there but maybe there is another way to write the volflow = DpQ(VardeltaP) expression
Top 4 tips 1. Knowledge is everything and Ignorance is dangerous. 2. Understand your limitations and try to eliminate them. 3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window. 4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials Last edited by ckleanth; June 30, 2009 at 05:36. |
June 30, 2009, 18:49 |
George
Rep Power: 18 |
still bugging me this flippin expression
June 30, 2009, 19:57 |
Rep Power: 144 |
Sorry, did not read your initial post fully - I don't think CEL interpolation expressions are sent to CFD-Post. The best way to check where on your curve your function is lying is to set up monitor points for the input and output of the expression then you can export them from Solver Manager and check them externally. Glenn Horrocks |
June 30, 2009, 20:03 |
#9 |
George
Rep Power: 18 |
thanks mate will try this tomo..
if I remember correcly fluent had this setup as ready made BC ... cant be that hard of a thing to do really... cant see any other way to model loads of fans/pumps inside a system using the machine characteristics...
August 24, 2012, 17:29 |
#10 |
Philippe Vidori
Rep Power: 15 |
Hello Sir,
I'm going through the same problem at the moment. Just curious to see if your model worked in the end. Best regards, Phil P.S: CFX is a pain with fans !! |
August 25, 2012, 07:23 |
#11 |
Rep Power: 144 |
Several post on this forum talk about this technique to model fans. It is quite commonly done and works fine when set up correctly.
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Porous domain vs Subdomain General Momentum Source | alvio | CFX | 1 | November 18, 2008 16:44 |
total pressure drop and momentum source setting | Li | CFX | 2 | July 28, 2008 03:33 |
How to apply negtive pressure to outlet | bioman66 | CFX | 5 | June 3, 2006 02:40 |
general momentum source in cylindrical direction | Atit | CFX | 1 | May 31, 2006 10:05 |
