Rep Power: 17 ![]() |
hi, everyone,
I simulate rotor 37 in CFX, but want to postprocess the result in Tecplot, i don't know how to cut a B2B surface because the CFX mesh is considered as unstructural. Could somebody help me? Thanks very much. |
Rep Power: 144 ![]() ![]() ![]() ![]() |
I think there is a tecplot export option. Go to the solver manager, under tools I think there is an export data gizmo. I don't have CFX in front of me so can't give you the exact location. Glenn Horrocks |
thanks Glenn,
i did the export of CGNS format, but there's no such an option as exporting a result basing on structural grid. the problem is in CFX itself, solving equationgs of conservation in unstructured grid. could i make some change by a coding or other methods, anyway, only to extract some surface like B2B in Tecplot? perhaps i must seek help in Tecplot helping PDFs. |
Well then you are stuck because CFX is an unstructured solver so there is no way it will output a structured grid. If your grid is actually structured you could write your own export routine then you would get a structured grid output. Have a look in the documentation for how to do this. But my guess is you will be unlikely to do better than the existing CGNS export so why not stick with that. I don't know what you mean by extracting surfaces. Do you want the full 3D domain or just the boundaries? What are you trying to do with the output anyway? Glenn Horrocks |
Thank you very much,Glenn,
I just want to make some turbo surfaces in Tecplot, such as that in CFX post turbo module. Thanks for your advice, I will try doing that in Tecplot, maybe this is the easiest practice. |
Rep Power: 0 ![]() |
I simulated a centrifugal compressor in NUMECA and imported the CGNS format flie into Tecplot. Now, I want to cut a B2B surface, such as that in CFVIEW or CFX post. Have you solved this problem in Tecplot? Thank you! |
comparison with analytical results (1D)and(3D) CFX | Rogerio Fernandes Brito | FLUENT | 1 | December 2, 2012 06:12 |
Reading CFX-CFD results without Ansys CFX | JAY | ANSYS | 2 | July 7, 2009 16:48 |
CFX - Tecplot | Ilona | CFX | 1 | September 2, 2004 00:20 |
CFX 5.5.1 and writing intermediate results | Andrej | CFX | 1 | January 18, 2003 21:00 |
CFX post to Tecplot | nandu | CFX | 2 | December 4, 2002 08:27 |
