June 19, 2009, 07:47 |
Spanwise Lift post-processing
Rep Power: 17 |
Hello guys. I simulated flow around a 3D wing and I am post processing the results.
Does the force_norm function in CFX ansys give the Force per unit meter one could use to get the lift distribution along the wing ? Or is it better to specify user surfaces from contours (contours of spanwise Z direction ) to cut the wing into sections and extract the total force acting on each user surface ? The problem with the 2nd option is with me when I try to extract a force on the user surface it hangs CFX for 10 mins for the first calculation , before it gives the result. Which technique do you guys use ? |
June 19, 2009, 08:01 |
Rep Power: 144 |
Read the documentation about the force_norm function. I am not sure but I think it only gives you the direction of the force vector. The best way to extract the data you want is as you suggest - make user surfaces and do force operations on each user surface. Glenn Horrocks |
post processing for KIVA | dirga | Main CFD Forum | 5 | April 23, 2009 11:58 |
Question about post processing | qtian | OpenFOAM Post-Processing | 0 | July 24, 2007 13:44 |
Tecplot for CFX post processing | pantangi goud | CFX | 2 | August 24, 2005 17:42 |
Post Processing in FEM | Abhijit Tilak | Main CFD Forum | 0 | April 26, 2004 12:59 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 21:51 |
