June 17, 2009, 06:06 |
Steady-state or transient?
Tuffy
Rep Power: 17 |
Hi everyone!
I'm using V12, and in particular the thermal electric coupled analysis. The simulation that I want analyze has to be transient, but actually it seems that using ANSYS workbench this is not possible. Does somebody know what I must change and where to obtain a transient analysis? Thanks in advance. Ema |
June 17, 2009, 07:20 |
Bostjan
Rep Power: 17 |
In CFX Pre you go Simulation => simulation type=> there you can select option steady state or transient
June 17, 2009, 07:25 |
Tuffy
Rep Power: 17 |
Thanks! I know that I can use the transient simulation in CFX, but do you think that importing an .inp steady-state file from thermal-electric in CFX the simulation that I will obtain is transient? Thanks!!!! Ema |
June 17, 2009, 09:12 |
George
Rep Power: 18 |
as far as i understand it for a coupled mechanical-cfx solution the two solvers need to run in parallel and exchange interface information
i dont know what the .inp file is as i for what i do never run anything coupled BUT in cfx a steady state simulation the timescale for each set of physics does not have to be the same. this is not the case for a transient simulation as every calculation needs to run at the same physical timescale. if the iteration from your mechanical simulation is considered as steady state regardless of the fluid iteration (I'm not sure if this is the case but go with me on this) essentially you dont want to run a coupled simulation but a transient cfx simulation and adding the mechanical source to your simulation. i hope this makes sense
Top 4 tips 1. Knowledge is everything and Ignorance is dangerous. 2. Understand your limitations and try to eliminate them. 3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window. 4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials |
June 17, 2009, 09:25 |
Tuffy
Rep Power: 17 |
Thanks,
the problem is that my idea is to have a continuous excange of data from cfx to mechanical, and this is why I want have in every case a transient simulation. The .inp file is something that I obtain writing the imput file, and once that I'm working on CFX I must upload this file, that contains data, loads and boundary conditions. The problem is that reading the code I can be sure that this file, and so the relative simulation is static and not transient... Thanks for your help, Ema |
June 18, 2009, 23:03 |
hun
Rep Power: 17 |
Hi Ema,
Try tutorial 4 in CFX pre. hung |
Steady State Vs Transient answers | Kushagra | CFX | 25 | July 23, 2017 04:20 |
Mass Diffusion: Transient and Steady State BC | rval | CFX | 3 | November 19, 2008 01:52 |
Steady state > Transient | Willem | FLUENT | 1 | June 24, 2008 12:18 |
time to reach steady state with transient simulati | prabhu | CFX | 2 | April 21, 2008 11:18 |
Transient vs Steady State | Adam | CFX | 1 | April 12, 2007 12:34 |
