Mesh Validation - Inlet
Old   June 15, 2009, 14:12
Default Mesh Validation - Inlet
Daniel is on a distinguished road
Greetings,
i want to Validate several Meshes in order to know which Number of Cells is enough so that the solution doesn't change any more.
Therefore i created for my geometry several meshes and refined them step by step. After running CFX Solve, i pointed in CFX Post to the inlet of my gas flow and let cfx post readout the velocities in 1- 20 mm distance of the inlet (1mm steps). The problem is now, that my velocity is increasing in the beginning of the inlet. but There is no change in the crosssection in the first 5 mm, and after that it rapidly changes (becomes bigger). Its like a free jet flow. so the velocities should go down.
Any ideas ?
Daniel is offline   Reply With Quote
Old   June 15, 2009, 21:18
You will need to provide more details of what you are trying to do. A picture of your geometry would help too, also the CCL is good.
Old   June 16, 2009, 03:30
Ok some Data about my simulation,
Using. SST model, supply Gas is Argon, T is 293 K (Isothermal in the reactor), Thermal Energy Modell is used. its a very simple geometry and so is the simulation. consider it just as an 5mm long tube with 8mm cross section (D0,inlet) and after that the cross section expands abruptly to more than 10*D0. Everything else in the Sim. should not affect this inlet problem
Old   June 16, 2009, 09:06
We will need more details to really help. An image of the region would be good, also be more specific about the velocities you are measuring.
But some thoughts (can't be too specific as I still have no idea what you are doing):
1) If you specify the inlet as constant velocity flow the boundary layer will grow causing the flow next to the walls to slow down and the central bit speeds up.
2) You said the flow is isothermal so I assume you are not modelling compressible flow? If you are modelling compressible flow you can get some strange effects as the flow expands out.
3) Are you sure your inlet is far enough upstream to not affect the results?
Old   June 16, 2009, 16:43
thanks for your reply again, but now i know what is wrong. The velocity profile at the inlet cross section is plug flow and of course it speeds up then when it develops a parabolic profile. so it was point number 1 you suggested. Thanks for the help!
validation
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 11:04
[Netgen] Same mesh on inlet and outlet henning OpenFOAM Meshing & Mesh Conversion 3 January 16, 2009 05:39
[mesh manipulation] TranformPoints gives skewed mesh Possible Bug andersking OpenFOAM Meshing & Mesh Conversion 3 March 25, 2008 22:33
Structured mesh refinement Andrea Panizza FLUENT 1 November 9, 2003 04:48
