Need help:about energy equation in CFX
Old   June 14, 2009, 23:45
Default Need help:about energy equation in CFX
Stein
Stein is on a distinguished road
Send a message via MSN to Stein
In CFX,two kinds of energy equation has been provided,i.e.Thermal energy equation and Total enthapy equation.SO ,my question is about two equations as follows?
Firstly:In theory ,two equations are equal,but why CFX provides these two options.What conditions can these two equations be used.
Secondly:In CFX_help documentation,only total enthapy equation for muti-component condition has been presented and described .So,does it mean only total enegy equation can be applied for muti-component,but Thermal energy eqaution not.
Thirdly.If I use Thermal energy equation to simulate combustion ,is there any reaction heat source term in this equation.Or,I wonder if combustion model is activated ,CFX will add heat source term to the equqtion automaticly?
Finnally.I hope someone can give me detalied explanation about the difference between these two equation and If I use total enthapy equation to simulate combustion ,is it all right?
Stein is offline   Reply With Quote
Old   June 15, 2009, 03:32
ckleanth's Avatar
George
ckleanth is on a distinguished road
the two energy models are not the same and nowhere in the documentation is saying that
check the combustor totorial to learn how to setup combustion. if the reactions you want are not in the standard libary you need to provide cfx with kinetic data
in an nutshel use total energy if you have high speed flows or phase change
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Old   June 15, 2009, 10:34
Stein
In theory,energy equation has a few representation styles,i.e.temperture as variable,thermal energy ,static ehthalpy ,or total enthalpy as variable and so on.
Also, these styles can be transformed to each other,so they are actual equal in theory.But when they present in CFD,they become not the same,and should be used in certain condition,why?
Particularly, in CFX ,only total enthalpy equation has been derived and described in multi-component part of HELP documentation,does it mean thermal energy cant be used to modeling multi-component flow?
And combustion actually can be treated as multicomponent reaction flow.So,the total enthalpy equation should be used to combustion modeling,isn't it?
At last ,I wanna know if thermal energy equation is used to model combution,is there reaction heat source term in thermal energy eqaution or just a eqaution without source term like total enthalpy eqaution.
Old   June 24, 2009, 21:44
Stein
Someone help me answer this question ,Thank you
Old   July 2, 2009, 23:31
HeKLeR is on a distinguished road
The thermal energyeqn is just the total energy equation minus the mechanical energy eqn.
The reaction heat release is included. Why would they not be?
HeKLeR is offline   Reply With Quote
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 07:06
I-Radiation Equation problem with CFX Parellel Scott CFX 2 January 9, 2007 21:39
Form of energy Equation Newbie FLUENT 2 March 9, 2004 08:16
how to disable energy equation for for non-newton yueroo FLUENT 2 April 3, 2001 23:11
Energy equation and Enthalpy Martin FLUENT 1 January 25, 2001 18:11
