June 11, 2009, 03:08 |
error message from solver manager
harry
Rep Power: 17 |
Hi all,
I encountered a error message from solver manager when I ran a transient simulation , it said, Details of error:- ---------------- Error detected by routine LOCDAT CDANAM = AROT/VALUE CRESLT = NONE Current Directory : /FLOW/PHYSICS/ZN1/MOTION Writing crash recovery file | ERROR #001100279 has occurred in subroutine ErrAction. Message: Stopped in routine MEMERR An error has occurred in fx5solve: The ANSYS CFX solver exited with return code 1. No results file has been created. In this simulation, I firstly made the domain rotating for a period of time, and a res file was generated at the end, as an initial value file for the following simulation, in which the domain suddenly stopped to be stationary. Has anybody encountered the similar problem please? Any method to fix it? Thanks a lot. |
June 11, 2009, 07:53 |
Rep Power: 144 |
I suspect that you are doing a rotating frame of reference simulation but have not defined the rotational speed. Make sure it is defined. Glenn Horrocks |
June 12, 2009, 07:54 |
Rep Power: 21 |
In the restart make the domain stationary by setting a value of zero for the rotation rate, rather than switching to a stationary domain.
Edit/stop run in progress without solver manager | N.R. | CFX | 12 | June 17, 2015 03:13 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 15:08 |
Solver Manager error message | Ste Lakey | CFX | 0 | April 26, 2005 06:58 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
