Possible to account for surface roughness with SST model? |
June 19, 2009, 04:34 |
#21 |
LSC
Rep Power: 17 |
Hi Timon,
I suspect that the version which I am using is an academic version which does not have the beta feature. If the beta features are incorporated, how do I go about enabling it? I read that the option is at the Launcher under EDIT>>OPTION menu but I don't see any in it.. |
June 19, 2009, 04:37 |
#22 |
Rep Power: 17 |
It is not a feature that becomes visible in cfx-pre when you enable beta-features. You just need to modify the ccl manually. One way to do this is by means of the method described in my previous post.
June 19, 2009, 05:03 |
#23 |
LSC
Rep Power: 17 |
Hi Timon,
which means that chances are the beta features are already incorporated in the V11 fully released version just that we might need to edit the CCL manually right? |
June 19, 2009, 05:12 |
#24 |
LSC
Rep Power: 17 |
Hi Timon,
I found the beta features! Many many thanks for your help. Will try out the roughness feature. |
June 19, 2009, 05:15 |
#25 |
Rep Power: 17 |
The beta-tag does not refer to the cfx-version but to the specific feature (in this case rough wall treatment for k-omega models). It means that the feature can be used but has not yet gone through extensive testing and validation. In cfx v12 rough wall treatment for k-omega models is no longer a beta feature, but a fully released feature, as it has gone through the testing procedures and been found to function properly. CFX mentions that rough wall treatment for k-omega models has been improved in v12, but what exactly has been changed I do not know.
June 19, 2009, 05:26 |
#26 |
LSC
Rep Power: 17 |
Hi Timon,
thanks for providing further insights. I am actually an undergrad working on my final year project and this is the first time I am being exposed to CFD. Since it is a beta feature, I am thinking it would be good that I test out these features and until when my school got V12 where my peers will do a comparison then. |
June 20, 2009, 03:47 |
#27 |
LSC
Rep Power: 17 |
how to I relate the equivalent sand roughness height to the Transition roughness height (which can be found under the transition model)? |
June 20, 2009, 08:07 |
#28 |
Rep Power: 144 |
You will need the documentation on this to understand what all the terms mean. That's one disadvantage with the beta software - no documentation. That's why you should push for your school to go to V12 ASAP. If that is not possible you should get your hands on the V12 documentation as that should explain how this feature works. Glenn Horrocks |
June 20, 2009, 09:21 |
#29 |
LSC
Rep Power: 17 |
Hi Glenn,
think it would be hard lay my hands on V12 and my project due in August (time is running out!) anyway. I'll see if I can get hold of the documentations. Once again, many thanks for all your inputs. I managed to get reasonably good predictions for the clean aerofoil data. Now will go into accounting for roughness effects which is what my project is all about. |
June 21, 2009, 08:54 |
#30 |
Rep Power: 144 |
Well, if you can't get your hands on the full V12 then at least get the documentation. You can download it from the customer portal on the ANSYS website. You will need a login to get onto the site but once there you will be able to download the V12 documentation. Glenn Horrocks |
June 24, 2009, 00:27 |
#31 |
LSC
Rep Power: 17 |
for the beta feature that was mentioned earlier about adding roughness using SST model, can transition model be turned on and predict as well? |
June 24, 2009, 00:53 |
#32 | |
LSC
Rep Power: 17 |
I managed to add roughness using SST model. I faced the same problem as you and found out that it works (solver has the roughness and SST model appeared) when you disable the auto physics update checkbox which is located at the option menu. Running the simulations now and fingers crossed! |
June 24, 2009, 00:56 |
#33 |
LSC
Rep Power: 17 |
Hi
just to check, when i start the solver and the roughness and SST appears in the CCL does that mean roughness has indeed been added? |
June 24, 2009, 02:40 |
#34 |
Rep Power: 144 |
The CCL reported at the start of the output file is the exact CCL used in the simulation. CFX-Pre does not support all the CCL available so some stuff has to be added manually. Glenn Horrocks |
June 24, 2009, 02:49 |
#35 |
LSC
Rep Power: 17 |
Hi Glenn,
I started with selecting RNG k-e model with roughness added on the wall boundary condition. Subsequently I export the CCL first and change the turbulence model to SST using Notepad and import back to cfx-pre. I disabled the auto update physics and save it to the def file. When I run the solver, I did a check on the CCL and indeed the roughness and SST command is there. Is this correct? Anyway I have run two simulations with roughness and without roughness using SST model with the rest of the parameters kept at constant. There is a huge difference.. |
June 24, 2009, 09:03 |
#36 |
Rep Power: 144 |
Don't import your CCL modifications to CFX-Pre. As I said, Pre does not support the the full CCL. You should use the command line "cfx5cmds -write -def Run1.def -text MyCCL.ccl" to put the CCL into the definition file. You can also add CCL statements from the command line option -ccl or the equivalent in soler manager but I prefer to have the full CCL as a file so the cfx5cmds method is better. Glenn Horrocks |
June 24, 2009, 13:51 |
#37 |
Bostjan
Rep Power: 17 |
Glen,
What is the procedure to import CCL modifications (CCL modified file) to put the CCL into the definition file? I am not sure how i can do this: you should use the command line "cfx5cmds -write -def Run1.def -text MyCCL.ccl" to put the CCL into the definition file Thanks |
June 24, 2009, 14:18 |
#38 |
George
Rep Power: 18 |
from the cfx launcher use tools>command line
to read CCL from the definition file cfx5cmds -def file1.def -text file1.ccl -read to write the modified CCL to the definition file: cfx5cmds -def file1.def -text file1.ccl -write if you do this for first time backup your files until you are comfortable of using the command prompt
Top 4 tips 1. Knowledge is everything and Ignorance is dangerous. 2. Understand your limitations and try to eliminate them. 3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window. 4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials |
June 14, 2014, 06:55 |
#39 |
Samir
Rep Power: 12 |
I am using fluent.. By default, the surface roughness is disabled.. how do i enable it ? and is adding values for surface roughness in fluent enough for computing results ?
June 14, 2014, 07:11 |
#40 |
Rep Power: 144 |
Try the fluent forum.
why SST model??? | vijay | CFX | 3 | May 22, 2008 04:05 |
SST model and boundary layers | Rodrigo Basniak | CFX | 7 | March 27, 2008 15:19 |
convergence about SST model | Wei | CFX | 7 | March 18, 2008 13:01 |
sst model | anish | CFX | 2 | April 30, 2007 07:37 |
k-w SST model keeps promise ? | Mark Render | Main CFD Forum | 0 | November 30, 2000 08:03 |
