Import data history
Old   June 5, 2009, 07:35
Lightbulb Import data history
Ema
Tuffy
Ema is on a distinguished road
Hi everyone,
I try to import datas that I save like .txt or .xml from CFX simulation or Thermal-Electric simulation to every kind of mechanical simulation...
Even if the file is not empty i have this error:
'either the specified location is incorrect or the source at that location contains no data'.
Does somebody know why and what I can do?
Thanks!!
Ema is offline   Reply With Quote
Old   June 5, 2009, 09:17
What are you trying to do? Use the result of a CFX or Thermal-Electric simulation as the input to a mechanical simulation? In this case you are trying to do a one-way coupled FSI simulation. There are tutorial examples showing how to do this. Also note the FSI capabilities of ANSYS were significantly enhanced in V12 so if you are not on the current version you should catch up.
Old   June 5, 2009, 09:53
Ema
Tuffy
My idea is to link CFX and Thermal-Electric in both directions.
I need to simulate the behaviour of a structure that has joule heating and a fluid flow.
So to do this I think I have to:
1) create a geometry, fix BC and voltage, obtain the heat flux with thermal-electric and export it
2) import the heat flux in CFX, or the temperature obtained from the thermal-electric and simulate the flow
3) import in a new thermal-electric the flow behaviour and simulate...
thanks!!!!!
Ema
Old   June 5, 2009, 10:48
ckleanth's Avatar
George
ckleanth is on a distinguished road
elecromagnetics are enabled as beta in cfx v11, fully supported in v12
you need to define electromagnetic properties for the materials
in your case for inlet electric field BC you can define Conservative Interface Flux, Flux in, Voltage, or Zero Flux. if you dont have magnetic field inlet should be Zero Flux and at the outlet 0 on x,y,z Cartesian Magnetic Potential Components
in V11 you need to define a bulk source jouleheating subdomain which is (1 / Electrical Conductivity) * abs( ( Current Density Y )^2) not sure if in V12 as I dont have acess to it yet
Top 4 tips
1. Knowledge is everything and Ignorance is dangerous.
2. Understand your limitations and try to eliminate them.
3. Get yerself a bike and hoon the chuffer. You will soon learn why dogs like to hang their heads out the car window.
4. Please before asking any questions on how to run simulations in CFX, go though all the tutorials
ckleanth is offline   Reply With Quote
Old   June 5, 2009, 10:51
Ema
Tuffy
I'm using the last version V12.
Thank you very very much!
Old   June 6, 2009, 08:44
So it sounds like you should be able to do what you want using the standard FSI capabilities in CFX and ANSYS Mechanical. No need to develop your own FSI interface.
Old   June 9, 2009, 05:28
Ema
Tuffy
Right, it is possible, using MFX that couples ANSYS Mechanical with FSI in CFX.
Thank you everyone.
Ema
Data import in Fluent?! Bart Horsten FLUENT 3 February 22, 2010 14:05
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
I-DEAS CAD data import with boundary conditions Yunus Siemens 1 June 1, 2001 11:04
I-DEAS CAD data import with boundary conditions Yunus FLUENT 2 March 14, 2001 15:45
