June 2, 2009, 04:16 |
Reynolds contour plotting in cfx-post
SMN
Rep Power: 17 |
hi:
i want to plot a contour plot for reynolds number in default domain in cfx-post...how can i do it??? best regards |
June 2, 2009, 20:02 |
Rep Power: 144 |
Define a function for Reynolds number, then it will appear as a variable you can do contours with. Have a look in the tutorials for how to do this. Glenn Horrocks |
June 3, 2009, 01:49 |
SMN
Rep Power: 17 |
hi Glenn Horrocks and thank you very much for all your helps:
the geometry is very complicated and i cant define any effective length in reynolds num.also the direction changes and i cant use parameters like y or z as diameter in CEL. the tutorial is very simple and i cant use it. |
June 3, 2009, 08:34 |
Rep Power: 144 |
Well if you can't define a length scale then how can you work out a Reynolds Number? I am guessing you are looking for the surface Re number to look for turbulence transition or turbulent boundary layer growth along a surface. This would be tricky to visualise on an arbitrary geometry. If you are using the turbulence transition model I think one of the variables modelled is in effect the surface Re number, that might help. Otherwise you might be able to define a length scale using surface streamlines where you use the position along the streamline as your length scale. Just an idea, it would be tricky to get working. Glenn Horrocks |
Transient animation performance in CFX 5.5 POST | Sjoerd Romkes | CFX | 8 | February 5, 2013 15:53 |
Assign new variable in CFX Post | Ben | CFX | 1 | August 25, 2008 15:59 |
Vof contour plotting | Shane | FLUENT | 1 | October 8, 2006 05:57 |
Reynolds Stress Model in Fluent Vs CFX | Tim | FLUENT | 0 | December 6, 2005 23:03 |
Contour plotting | Mark Russell | Main CFD Forum | 5 | April 22, 2000 23:45 |
