Complicated CAD import, how do I find fluid volume?
Old   May 31, 2009, 12:52
Default Complicated CAD import, how do I find fluid volume?
David
dgzilber is on a distinguished road
Hi ,
I have searched this forum, the web, and the help files of CFX extensively but have been unable to find helpful results. I am importing a CAD file and from this CAD file, I must generate a mesh of the liquid volume, not the volume of the solid itself, in order to perform computational fluid analysis using the CFX suite.
In ANSYS workbench, I have tried to use combinations of add material and cut material, in conjunction with a larger solid block, using the Design Modeler software. However, this is quite cumbersome, and I would imagine that there is a simpler way to do this.
If someone could help me find the liquid volume using this simpler way, I would be very much grateful.
Thank you for your time,
David
dgzilber is offline   Reply With Quote
Old   May 31, 2009, 20:01
Use the fill command in Workbench.
Old   June 1, 2009, 04:40
David
I have tried the fill command as well, but for some reason, every time I use it I receive an error regarding the programs inability to heal wounds.
"Cannot heal patch/wounds from removed faces. Context: Geometry Engine, while generating feature Fill1. Error: Fill operation failed. Context: Fill Feature Fill1."
I have tried creating simple geometries, with the goal of obtaining a successful fill, but anything more complicated than a tube results in an error.
What am I doing wrong?
Old   June 1, 2009, 19:46
There are some tricks to getting some of these commands to work - and I am not going to write a thesis on how to do it (maybe I am just lazy). Do lots of examples, do some CFX training is all I can recommend. Also there are several ways of doing it in CFX. Fill is one way, cutting bodies is another. You can also use the CAD import cleanup stuff.
How to create a fluid volume inside a solid volume sanin FLUENT 4 November 13, 2008 16:17
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
define the fluid volume nessi benishti FLUENT 0 August 2, 2005 17:57
VOLUME OF FLUID Nial Horton FLUENT 6 June 28, 2004 05:43
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
