Fixed temperature for domain
Old   May 26, 2009, 20:02
Default Fixed temperature for domain
seojaho is on a distinguished road
I wounder how to apply a fixed temperature to a domain in CFX-Pre?
For a boundary condition (2D), there is an option to give a fixed temperature.
For a domain (3D), I created a subdomin for the domain (but actually, the submain is the same as the domain). However, there is no option for giving a fixed temperature over the domain.
Please let me know how to deal with this problem. Thank you very much.
Jaho
seojaho is offline   Reply With Quote
Old   May 30, 2009, 13:25
Zef
Zef is on a distinguished road
You can do an isothermal analysis and set the domain temperature (Domain->Fluid Models->Heal Transfer->Isothermal). But if you have a multidomain situation, then all the domains will be isothermal. You cannot set the temperature for one domain and solve the Energy Equation for another one.
Zef is offline   Reply With Quote
Old   May 31, 2009, 20:08
Can you explain why you want one domain to be fixed temperature?
Old   June 1, 2009, 11:07
Thank you, Zef. It's helpful.
Have a great day!
Old   June 1, 2009, 11:10
For steady state simulation, I wouldl like to set one domain to have a fixed temperature. Actually, one domain is sort of a heat source such as molten metal to be poured continously.
Old   June 1, 2009, 19:34
If the region is fixed temperature then why model it at all? Why not just model its boundary on the domain you are modelling as a fixed temperature?
Old   June 2, 2009, 11:36
Thank you for your reply, Glenn.
Glenn, I want to know how to model to give a fixed temp. for 3D domain instead of 2D boundary condition...
Is there any way?
Thanks
Old   June 2, 2009, 19:49
But if you assume it is a fixed temperature then you are not modelling anything so why bother?
You can fix values using a heat equation source term to fix the temperature of a region to a value you define. This way you can set one region to have fixed temperature but elsewhere the temperature is calculated as normal. Is this what you want to do? Look in the documentation under source terms.
Old   June 4, 2009, 14:21
Hi Glenn,
I am sorry for late reply. Thank you for your help and have a great day.
Jaho
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
High temperature methane+air Peter FLUENT 5 January 26, 2009 19:04
Fixed Temperature in StarCCM+ Oliver Siemens 4 September 8, 2008 08:22
Question about the resistance in fixed temperature oniboy Siemens 0 February 29, 2008 00:00
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
