tutorial for CFD & acoustic analysis ansys workbench 11 |
#21 | |
Rep Power: 0 ![]() |
There are no variable ultrasonic frequency transducer. The purpose is to determine the optimum frequency and fabricate the transducer. |
#22 |
Rep Power: 144 ![]() ![]() ![]() ![]() |
Sure you can:
http://www.iultrasonic.com/ultrasoni...st-d700cr.html http://www.brainpowerusa.com/shoppin...275&bestseller http://www.mpi-ultrasonics.com/conte...sonic-cleaning Anyway: The CFD model you describe is going to be so difficult and complex that I would recommend strongly against it. The only way I can see to practically model what you describe is with some reduced order modelling, or a model which looks at how strong the pressure waves are at the cleaning location and you infer cleaning effectiveness from that. |
#23 |
ken mingzhi
Rep Power: 9 ![]() |
#24 | |
ken mingzhi
have you find out the solution ? I'm doing the same need some guidance |
#25 |
If you are trying to model linear acoustic waves in a liquid then CFX does not sounds like an appropriate tool. Something like SYSNOISE or other acoustic simulation software would appear more suitable. I think ANSYS Mechanical has some new acoustic capabilities in the new release as well (V18.2).
#26 |
ken mingzhi
which is the proper way of doing this type of analysis ? whether it involves programming or not ?
#27 |
I do not have time to write step by step guides, I am a busy person.
If you describe what you are trying to do we can suggest whether CFX is a suitable software. |
#28 |
ken mingzhi
I am trying to find out flow rate of natural gas by passing out ultrasonic waves
#29 | |
ken mingzhi
hey gorrocks! I clamp two transducers at 45 degree to each other,how can I send and receive ultrasonic waves from them? kindly guide |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 09:23 |
[ICEM] what does the different ANSYS ICEM and ANSYS Workbench? | agungwp | ANSYS Meshing & Geometry | 8 | April 12, 2016 04:51 |
Macro command combatibility ANSYS workbench | Tassos | CFX | 6 | January 13, 2014 04:19 |
tutorial for CFD & modal (acoustic) analysis ansys workbench 11 | badterojan | ANSYS | 1 | June 18, 2009 10:29 |
Ansys Workbench 10.0 | Merkur | CFX | 1 | June 16, 2006 06:19 |
