May 22, 2009, 23:41 |
where we could read the properties value?
agung wulan piniji
Rep Power: 17 |
hai all, as usually i used cfd to see the flow visualization in post processing. iam little confuse with how to read the value of properties such drag and lift coefficient, temperature, pressure, etc. could you help me to overcome. where and how i could read the properties not in flow visualization but in number and data.
thank you |
May 24, 2009, 20:20 |
Rep Power: 144 |
In CFD-Post you can use the function calculator to give you the forces in the three coordinate directions on a surface. From these forces you can calculate CL, CD, centre of force etc. Glenn Horrocks |
May 26, 2009, 01:10 |
agung wulan piniji
Rep Power: 17 |
yah i know, but where i could get the aerodynamic forces and moments?
May 26, 2009, 01:32 |
Rep Power: 144 |
??!!!?? The CFD-Post function calculator gives you the aerodynamic forces and moments. So what are you looking for? Glenn Horrocks |
Chemical properties that are used in Fluent | kimej | FLUENT | 4 | August 19, 2011 11:29 |
Properties of air versus temperature AND pressure | Vincent | Main CFD Forum | 5 | July 28, 2008 06:28 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
how to read a gridpro 2d file into starcd shell | prc | Siemens | 3 | December 21, 2006 18:59 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
