CFX12 rif errors
Old   May 22, 2009, 23:16
Default CFX12 rif errors
zzc
romance is on a distinguished road
Hi all:
| ANSYS CFX-RIF 12.0 |
| Copyright 1997-2008 Advanced Combustion, Aachen, Germany |
| and ANSYS UK Ltd. |
Host computer:
Job started: Sat May 23 10:13:02 2009
| Writing materials and reaction CCL to |
| D:\CFX12\aaa.ccl |
Calculating flamelet library: CFX RIF 1
0% Scalar Dissipation Rate = 0.0000e+000
5% Scalar Dissipation Rate = 1.0000e-002
10% Scalar Dissipation Rate = 1.4678e-002
15% Scalar Dissipation Rate = 2.1544e-002
20% Scalar Dissipation Rate = 3.1623e-002
25% Scalar Dissipation Rate = 4.6416e-002
30% Scalar Dissipation Rate = 6.8129e-002
35% Scalar Dissipation Rate = 1.0000e-001
40% Scalar Dissipation Rate = 1.4678e-001
45% Scalar Dissipation Rate = 2.1544e-001
50% Scalar Dissipation Rate = 3.1623e-001
55% Scalar Dissipation Rate = 4.6416e-001
60% Scalar Dissipation Rate = 6.8129e-001
65% Scalar Dissipation Rate = 1.0000e+000
70% Scalar Dissipation Rate = 1.4678e+000
75% Scalar Dissipation Rate = 2.1544e+000
80% Scalar Dissipation Rate = 3.1623e+000
85% Scalar Dissipation Rate = 4.6416e+000
90% Scalar Dissipation Rate = 6.8129e+000
95% Scalar Dissipation Rate = 1.0000e+001
100% Turbulence PDF Integration
| Warning! |
| Return value C000001D >FFFF in parse_rv, treating as not-run. |
| An error has occurred in cfx5rif: |
| Turbulence PDF integration aborted for unknown reasons. |
romance is offline   Reply With Quote
Old   June 26, 2009, 08:39
Alberto Lopez
Albertolopez is on a distinguished road
Hello, everybody.
I'm getting the same error with CFX v.12, and I had no problem with the previous stand-alone version of CFX-RIF. Any idea about what could be happening?
Thanks in advance.
Albertolopez is offline   Reply With Quote
Old   October 21, 2009, 05:10
onn23 is on a distinguished road
I'm having same problem. What could be the reason?
onn23 is offline   Reply With Quote
Old   October 21, 2009, 05:47
Alberto Lopez
Hi all,
I found out that, even though CFX-Rif is now included in CFX you need an extra license in order to run the library generator.
So if you want to use it you have to pay.
Old   October 26, 2009, 14:41
Default License issue
Daniel Ribeiro
ribeiro is on a distinguished road
This is a license issue indeed. You must have a valid license file for RIF. This license should run under CFDS (old CFX daemon) which is available from CFX-5.7 installation. I believe this is a transitory situation and will be fixed for version 12.1.
Regards,
ribeiro is offline   Reply With Quote
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
