Error when importing cgns mesh created with numeca
Old   May 14, 2009, 04:58
Default Error when importing cgns mesh created with numeca
Pe2
Petter
Pe2 is on a distinguished road
Hi
I do some turbomachinery simulations. For grid generation I use numeca, and for the simulation I use CFX11.
Numeca creates the mesh in cgns.
When I import the mesh I always several error messages of this type:
GTMAPI::importmeshToModel - The importing process reported the following warning(s) while importing
the mesh from the requested file:
  Unable to map nodes in interface "bc_6" between Zone "row_1_flux_1_Blade_1_down"
  and "row_1_flux_1_Blade_1_up" as the not all nodes could be equivalenced.
The simulation runs and I don't think I have any issues with this problem, but I am not sure.
So my question is: Have anyone else had this problem? Do you know what causes this? And does it influence the simulation result?
Pe2 is offline   Reply With Quote
Old   May 14, 2009, 19:30
I think this error is saying it can't equivalence nodes across a periodic boundary. If the nodes across the periodic boundary don't match then ignore the error and use a GGI periodic boundary. If they should match then you will probably adjust the equivalencing tolerance so they match. Then you will be able to use a 1to1 periodic boundary and this is faster and more accurate - but not a show stopper if you can't do it.
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Null Domain Pointer Error when importing CGNS mesh Matt FLUENT 2 November 26, 2005 02:01
Importing Patran mesh into Gambit Trac FLUENT 1 September 29, 2005 11:32
importing mesh into fluent ch FLUENT 11 July 7, 2005 17:42
Problem importing ANSYS mesh, please help Ankan Kumar FLUENT 1 February 2, 2003 09:38
