Problem with rotating SOLID domain
Old   May 8, 2009, 04:38
Default Problem with rotating SOLID domain
Roland Rakos
Roland R is on a distinguished road
Hello CFX Users,
I calculate a centrifugal compressor. The flow field of the impeller is modeled with rotating domain. I would like to take the solid domain into account due to the heat transfer but it can not be defined rotating solid domain. There is an alternative: CFX Pre/Edit/Options/CFX Pre/Enable Beta Features. The rotating solid domain can be defined with this setting in principle. I have tried this way, but I think from the results that this solution is not correct. Does anybody have other solution perhabs?
Thanks
Roland
Roland R is offline   Reply With Quote
Counter rotating wall for rotating domain melvin CFX 0 February 4, 2008 05:51
Single Rotating Domain Sans CFX 3 October 26, 2007 03:33
CHT Problem - Domain Imbalance Parthipan CFX 5 September 11, 2007 11:13
Solid particles in a rotating vessel with 5.7.1 Sandeep CFX 0 May 17, 2005 11:54
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
