ERROR when i am using IAPWS table
Old   May 7, 2009, 11:12
Exclamation ERROR when i am using IAPWS table
Sudhakar P
kpsudhakar is on a distinguished road
Send a message via Yahoo to kpsudhakar Send a message via Skype™ to kpsudhakar
Hi everyone,
I am working in single stage steam turbine with wet steam model.Initially I have tried with IAPWS table but i couldnt succede,so i start my sollution with RGP table(SteamLP) and converged the sollution.
Then finally I interpolate the RGP table results with IAPWS table defenition file,then i start the sollution with lower time scale(1e-6) I am getting the following error
" Fatal bounds error detected
Variable: Steam1v.Specific Heat Capacity at Constant Volume
Locale : Rotor1"
Please help me to sort it out this issue.
kpsudhakar is offline   Reply With Quote
Old   May 13, 2009, 10:37
Adam Beevers
Adam Beevers is on a distinguished road
Hi Sudhakar
The problem is that during the initial stages that not all of the flow has thermodynamic properties in the correct region of the steam table of which you hope to end up. So sometimes the steam tables go outside of their valid range and the properties such as Temperature and Pressure etc become unphysical.
Often, when dealing with wet steam, expecially with wetness at the inlet, you need to start with an initially dry simulation to set the pressure field, as the steam models require this pressure field to determine where nucleation takes place.
Regards
Adam
Adam Beevers is offline   Reply With Quote
Old   May 13, 2009, 12:04
Timon is on a distinguished road
Have a look at the expert parameter "prop interp option", which handles the interpolation and saturation clipping (which is performed by default) of the thermodynamic properties... Setting "prop interp option=1" disables the saturation clipping, which might improve things for you.
Timon is offline   Reply With Quote
Old   May 20, 2009, 14:09
Marcin
pacmaan is on a distinguished road
I have another solution. You must create new material and choose IAPWS IF97 in Material Group (Basic Settings tab). Afterwards fill Table Generation in Material Properties tab.
Regards
Marcin
pacmaan is offline   Reply With Quote
Run time Selection Mechanism - Some help required to understand jaswi OpenFOAM Programming & Development 3 October 29, 2015 14:42
Table Manipulation furkan Siemens 0 April 4, 2006 11:23
how to expend the table limingtiger Siemens 0 October 30, 2005 03:45
Transient user input table Bart Siemens 0 January 10, 2005 02:27
use table Moon Siemens 6 September 18, 2003 09:58
