May 5, 2009, 12:08 |
Pressure Rise Error
Ed Mueller
I am doing an analysis on cavitation in a pump. I set my outlet static pressure to be a certain pressure and define a velocity profile at the inlet. I then iterate on my outlet pressure until my inlet static pressure is what I want it to be (-5 psi). With my cavitation off model, this has worked well. I get an outlet pressure of 80 psi and an inlet pressure of -5 psi, for a pressure rise of 85 psi. However, with cavitation on, my inlet pressure will not change with differeing outlet pressures. My goal is to get an inlet pressure of -5, and to do this I have set outlet pressures at 80,70,60,50,and 40 psi. For each outlet pressure, the inlet pressure is at -11 psi. I know that with cavitation on, the pressure rise should not be 1-to-1 like it is with cav off, but my inlet pressure should not be unchanging. I did not try any outlet pressures above 80 psi because it would not make sense that my cav on has a higher pressure rise than with cav off. Also, my model is well converged (with domain imbalances at or below 0.1%). I put a monitor point at inlet pressure and outlet massflow, and outlet massflow is what my calculated value is, and inlet pressure has leveled off before the run converges. I have tried with both low blend factor and high resolution schemes, and each time, I initialize my model with the results from the cav off run. Anyone run into this before or have any ideas what's going on here? Thanks, Ed Mueller |
cavitation, error, pressure rise, pump |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
OpenFoam 14 installation problem | gfcoppola | OpenFOAM Installation | 20 | November 2, 2007 14:38 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
