April 27, 2009, 08:59 |
About Gravity Option
Kuldip
I am new to CFX. I am using particle tracking model in steady state. Now i want to switch ON the gravity in CFX-POST. From where shall i start it?
Thank You very much |
April 27, 2009, 22:32 |
Rep Power: 144 |
CFX-Post is the post-processor. It you want to switch gravity on you will need to go back to CFX-Pre to set gravity on and redo the simulation. Glenn Horrocks |
April 29, 2009, 10:51 |
Bharath kumar
Rep Power: 17 |
hi glenn,
what is buoyancy reference density?whether it is particle density or fluid density? |
May 4, 2009, 04:51 |
Matthias Voß
Rep Power: 20 |
hi,
it is the fluid density... the difference to that density represents the ammount of the liftforce. neewbie |
May 4, 2009, 08:20 |
Susann
Rep Power: 17 |
There are two different models in CFX for buoyancy...the one that's used depends on the properties of the fluid you select...for free surface flows it's recommended to choose the density of the lighter fluid/material!!! But i don't know if thats the same with your case with particles...
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 33 | August 16, 2024 06:09 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 04:30 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
about compresive phase | James | CFX | 10 | September 12, 2006 04:16 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
