NACA 4 digit simulation - not converging
Old   April 23, 2009, 07:11
Default NACA 4 digit simulation - not converging
dublin is on a distinguished road
I'm doing simulations on a NACA 2408 aerofoil, and at angles of attack of about 10degrees or greater it just won't converge, and normally the graph that shows when the solver is running falls into a periodic pattern. I've tried the simulation with various meshes (i.e. more elements in the mesh) and added layers to the inflation boundary around the aerofoil without luck. I've also tried to change from Auto timestep to physical timestep, trying a couple of values there but still no luck. I'm running SST turbulence, and it's a steady state simulation. I'm a complete novice with CFX and any tips on how to get it to converge would be much appreciated, thanks.
dublin is offline   Reply With Quote
Old   April 23, 2009, 19:36
hi,
Have a look at:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
I bet it is going transient as you approach the stall point.
Old   April 24, 2009, 08:27
Thanks for that. Not really sure what I'm doing now but I'll see if I can get it to run as a transient simulation.
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
NACA 2412 simulation in CFX - 2nd Run andrew CFX 12 December 18, 2013 09:34
2D NACA 0012 simulation in CFX Hao CFX 29 March 20, 2009 06:38
NACA 0012 simulation results Luis FLUENT 3 February 15, 2006 12:42
NACA 2412 simulation in CFX andrew CFX 17 October 26, 2005 02:38
