simulate Check valve in 2D
Old   April 17, 2009, 08:36
Question simulate Check valve in 2D
Xue-Guan Song
songxguan is on a distinguished road
Hello everyone,
I'm doing a anlaysis about 2D check valve (radius is 'R'), which has a spring to support the disc, and is axi-symmetical.
I wish to solve it in 2D, and the simply way is to extrude one layer mesh(thickness is 't') and then do the so-called 2D analysis, but there is a question, when i do like this, how should I define the spring stiffness 'K'? it's same as before
or is should be calculated like this: ((t*R)/(Pi*R^2))*K
because the original force on the ball is P*(Pi*R^2), but now is just P*(t*R).
Is there anybody can help me ?
Thanks in advance.
songxguan is offline   Reply With Quote
Old   April 18, 2009, 13:06
Martijn
Martijn is on a distinguished road
Yes ((t*R)/(Pi*R^2))*K=K2D is probably the best solution if you want to simulate the valve in 2D.
But why don't you run the simulation as an axi-symmetrical problem?
Martijn is offline   Reply With Quote
how ot simulate orifice valve ammi reddy FLUENT 0 April 4, 2007 08:07
How can i simulate a valve motion ???????? popi CFX 6 September 19, 2006 11:54
How to simulate valve with pressure BC? Luk FLUENT 8 June 20, 2006 09:06
Valve Forces in CFdesign Mike Clapp Main CFD Forum 3 March 8, 2001 15:09
CFD of tilting disk check valve Greg Anderson Main CFD Forum 1 July 13, 1999 18:07
