Problems modeling subsonic engine air inlet with flow separation
Old   March 27, 2009, 17:42
Default Problems modeling subsonic engine air inlet with flow separation
TWaung is on a distinguished road
I need to model an air inlet for an air breathing engine (RBCC engine). Flow velocities through the duct are subsonic (Mach 0.2 - 0.5). The average static pressure at the outflow plane of the air inlet is fixed. I am having convergence problems in the regions of flow separation and I was wondering if anyone has any suggestions on how to improve convergence.
I have tried increasing mesh density in the regions of separated flow but so far this has not helped. (I am also reaching the memory limits of the computers I have access to.)
I have been hesitant to extend the domain past the true outflow plane since I need to achieve a given average pressure at this plane. Is it typical to extend the domain past the true outflow plane for simulations? If so, how does one achieve the desired pressure at the true outflow plane location? (iteration?).
The simulation details are as follows.
Domain Settings
Steady state
Using SST turbulence model, Ideal Gas, Total Energy model
Boundary conditions
- subsonic velocity inlet
- opening pressure outlet. Using the entrain setting since I expect there to be regions of separated flow crossing the outflow plane. I have been hesitant to extend the domain past the true outflow plane since I need to achieve a given average pressure at this plane.
Solver Settings
Advection scheme: High Resolution (when using UW scheme, the simulation converges)
Timescale control: Local Time scale
Any suggestions would be greatly appreciated!
Thanks
TWaung is offline   Reply With Quote
Old   March 29, 2009, 18:52
Have a look at:
http://www.cfd-online.com/Wiki/Ansys...gence_criteria
Try the recommendations on that page but I bet in your case you have transient flow structures so you will need to run a transient simulation.
Old   March 29, 2009, 19:42
Thanks Glenn,
I'll give the transient simulations a try.
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 17, 2003 20:23
PhD in turbulence Hans Main CFD Forum 14 October 8, 2001 04:03
