Please help, Error: No FSIN boundary conditions defined in the model.
Old   March 27, 2009, 15:38
Default Please help, Error: No FSIN boundary conditions defined in the model.
Faraaz
cfxuser1 is on a distinguished road
I am trying to run ansys cfx in a script file (or batch file) at a command line. This is a FSI problem. The line i used to run cfx and ansys is as follows:
cfx5solve -double -def flagwithoutpoleU8.def -ansys-input FSIU8.inp
this line launches both ANSYS and CFX Solvers, starting from the definition file flagwithoutpoleU8.def and using the ANSYS input file FSIU8.inp. I got that line from the Ansys cfx help manual.
But for some reason I am getting the error message as shows below:
ADDITIONAL SYNCHRONIZATION FOR CFX:
SECOND SYNCHRONIZATION POINT OF MASTER CODE:
GET INTERFACE MESHES, INITAIL VALUES, and RESTART LOADS
*** ERROR *** CP = 0.140 TIME= 19:11:26
I don't understand why am getting this error message. The FSIN boundary condition was properly defined in cfxpre with the Ansys input file filepath correctly chosen. The .def file was then written.
However when run i am getting the error message above. Can anybody please help me. I really need to figure this out urgently.
Thanks
cfxuser1
cfxuser1 is offline   Reply With Quote
Old   April 29, 2009, 16:36
Vivek Kumar
vivekcfd is on a distinguished road
The best way to is to check your file FSIU8.inp carefully for the FSIN string. You can search for a line like SF,all,FSIN,1 in this input file.
vivekcfd is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
error using combination of step function xujjun CFX 1 January 15, 2008 17:46
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 08:15
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
