Problem with loop in CFX-Post macro
Old   March 26, 2009, 10:20
Default Problem with loop in CFX-Post macro
chris_101 is on a distinguished road
Hi everybody!
I am trying to evaluate a frequency-dependent expression inside a loop for different frequency values. A minimum example looks like the following:
!for(my $frequency=100;$frequency<2000;$frequency+=10)
LIBRARY:
CEL:
EXPRESSIONS:
testvalue=$frequency
END
END
END
EXPRESSION EVALUATOR:
Evaluated Expression = testvalue
END
> forceupdate EXPRESSION EVALUATOR
!my ($result,$unit) =evaluate("minVal(testvalue)\@Volume0");
!print "\n $result \t $frequency";
The problem is that the expression 'testvalue' remains at the value 100 which is the starting value of the for-loop. The output of this function is:
100 710
100 720
100 730
100 740
100 750
100 760
Does anybody have an idea how I could force an update of the expression value so that 'testvalue' and 'frequency' are equal while the loop is running? The output I am looking for would be:
710 710
720 720
730 730
740 740
750 750
760 760
Thanks for your help!
chris_101 is offline   Reply With Quote
Old   March 26, 2009, 12:12
LKF
LKF is on a distinguished road
CFX Help for the minVal function states: "minVal Returns the minimum value of the specified variable on the specified locator. You should create a User Variable if you want to find the minimum value of an expression."
I belive the following code block will make your simple example work. Whether or not you can modify it to work for your intended purpose I don't know.
!for($frequency = 100; $frequency <150; $frequency +=10)
USER SCALAR VARIABLE:testvalue
  Boundary Values = Conservative
  Calculate Global Range = Off
  Expression = $frequency
  Recipe = Expression
  Variable to Copy = Pressure
END
!open (MYFILE, '>>.\Out.txt');
!my ($result,$unit) = evaluate("minVal(testvalue)\@Plane1");
!print MYFILE "\n $result \t $frequency";
!close (MYFILE);
I hope that helps.
LKF is offline   Reply With Quote
Old   March 26, 2009, 12:45
Default It works
I managed to get it work by adding some user variables for every perl variable that's changing inside the loop like you did in your listing.
I think the clue for getting the expression updated every loop-cycle is to store the dependent variable somewhere.
Thanks LKF!
Old   March 26, 2009, 14:18
cfdguy's Avatar
cfdguy is on a distinguished road
Sometimes I have problems with these IsoVolumes. What I usually do, I delete and redefine them at each loop.
For me, this is a POST issue, not a Perl one.
cfdguy is offline   Reply With Quote
Problem on mesh import to Ansys CFX 10.0 Stephen Lau CFX 1 April 18, 2007 04:02
Macro problem cfddummy Siemens 1 April 9, 2007 13:37
Proper output of angle of attack in CFX post Kevin CFX 3 October 18, 2006 13:18
TECPLOT 10 macro problem Matthew Morse Tecplot 5 July 5, 2004 02:31
Big loop problem of fortran Wen Long Main CFD Forum 9 April 1, 2004 13:38
