March 23, 2009, 04:15 |
How to simulate a plane with propeller
Lukasz
Rep Power: 17 |
Hi all,
I have following problem. Simulating a propeller (or fan) we usually use "circular" symmetry: we model the flow domain around single blade and after that use symmetry on both sides. We apply rotation and so on... and achieve fan specifications. But what to do in case of for example plane or hovercraft that also has a propeller but has no circular symmetry in the rest of the construction (a hull, wings)? Is it possible to simplyfy calculation in CFX using some symmetry criteria or to calculate in steps, for example a propeller at first and after that using momentum source for the rest of the plane? I would be very grateful for any suggestions, Luk |
March 23, 2009, 23:44 |
Rep Power: 144 |
In this case we use multiple domains. One domain is a rotating frame of reference and the other is stationary, and they are connected with a GGI (the general domain interface). Regards, Glenn Horrocks |
March 24, 2009, 04:34 |
Lukasz
Rep Power: 17 |
Hi Glenn, thanks for Your reply but it is not exactly my point. I know that the domains should be connected by interface (as it is also with propellers if You want to simulate some far "inlet" or "outlet"). But in case of simulating only properller You are able to use "circular" symmetry what dramatically reduces the mesh, time consuption and so on... My question is: are similar things possible with simulation of the for example propeller and the plane hull that has no circular simmetry.
For example, simulating plane with propeller in the nose: can I simulate half of the hull (symmetry BC in plane along the hull) and a single blade of propeller (defined as rotating domain) with circular simmetry. Simulation of full plane will be very demanding for hardware - entire hull and a multiblade propeller (rotating domain). Luk |
March 24, 2009, 17:13 |
Rep Power: 144 |
Yes, you can use symmetry and periodicity and combine with multiple frames of reference. You can do this with the frozen rotor or stage averaging approach. Glenn Horrocks |
March 25, 2009, 04:04 |
Lukasz
Rep Power: 17 |
Niiiiice!!!
Thanks You very much! Luk |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
ICEM and symmetry plane | Roland | CFX | 3 | September 13, 2006 09:38 |
simulate a tank equipped with propeller inside | aloha5i | CFX | 0 | October 15, 2005 16:56 |
Boundary zones in Gambit for a 3D propeller. | Craig Paxton | FLUENT | 1 | June 10, 2002 13:57 |
Mixing plane geometry definition | Hbet | FLUENT | 0 | January 18, 2002 08:16 |
