doubt: turbine side analysis logic
Old   March 17, 2009, 09:39
Default doubt: turbine side analysis logic
jai
jaikrishna
jai is on a distinguished road
in cfx i'm assign that(turbine domain- i'm analysing automotive turbocharger),
it is a rotating domain with angular velocity of some rpm (ex: at 90000 rpm).
my question is generally we donot know the turbine speed but we know the gas velocity or pressure and temperature at inlet.
whether it is wrong or myself following the wrong method of assigning..
jai is offline   Reply With Quote
Old   March 17, 2009, 17:24
The simple approach here is to guess a turbine speed, simulate it and check whether the output torque is correct. You then adjust the turbine speed until you get the correct output torque and that's you operating point. It is an iterative approach.
A more complex approach is to link the output torque of the turbine to the speed so a single simulation "homes" into the correct output torque. This approach is cleaner and potentially more accurate but the implementation can be tricky - you will probably have to under-relaxation the turbine velocity changes or use some other form of numerical stability method to obtain convergence.
I would recommend the first approach (the iterative approach) unless you are very confident in CFX and numerical methods.
Old   March 18, 2009, 09:38
Default Re: turbine logic
jai
jaikrishna
sir
i'm not asking how to determine the correct speed of the turbine. if it's compressor means it is run by some kind of prime mover so we can able to guess the speed.
but in turbine we donot know the speed. here we extract or convert the kinetic energy to mechanical energy.
whether in CFX possible to assign the domain as rotating domain with out rotational speed. because it spin depends up on the inlet fluid's temperature and velocity..etc.
blade analysis of gas turbine Fayyaz Husain Main CFD Forum 1 March 3, 2010 02:13
radial turbine flow analysis ME CFX 6 July 11, 2007 23:47
radial turbine flow analysis ME FLUENT 0 July 2, 2007 10:18
turbine blade analysis sajjad ahmad Main CFD Forum 0 June 20, 2007 07:30
two-dimensional gas turbine analysis Muhammad Usman Qureshi Main CFD Forum 0 March 14, 2007 13:01
