March 16, 2009, 13:35 |
CFX Mesh from Pro-e
Rep Power: 17 |
I am new to CFX and ANSYS. I am trying to generate a mesh from Pro-e geometry for use in CFX to perform analysis. Thus far - I have not found a method other that using iges from Pro-e for import into ANSYS - then writing the file for CFX using a .cdb file
Does anyone know of a better method? Perhaps using STEP file? I have access to ANYSYS Workbench, ANSYS, and ICEM as well as CFX. Thanks in advance to all. |
March 16, 2009, 15:16 |
Re: CFX Mesh from Pro-e
Rep Power: 17 |
I am not familiar with Pro-e, but if the option is available to save your model in parasolid format, you can import that directly into CFX-mesh.
Available for purchase from ANSYS is a bi-directional CAD connection as well. We're using that with SolidWorks and it works nicely. |
March 17, 2009, 12:21 |
Rep Power: 17 |
LKF is right.
Go for Parasolid or purchase the plugin instead (recommended). |
March 17, 2009, 21:22 |
Rep Power: 17 |
Thanks for the tip about parasolid - I can create that format from Pro-e but do not see where you can import that directly into CFX. Could you tell me a bit more detail on the technique? Do you have to create a mesh in ANSYS - or am I missing something where the parasolid can be imported directly.
thanks again |
March 18, 2009, 07:28 |
Rep Power: 17 |
The parasolid file can be imported directly into CFX-mesh (or one of other Workbench mesh utilities). You still need to generate a mesh and then import either a .gtm or .cmdb (mesh file) into CFX-Pre.
Create fine mesh that grows to coarse mesh (Urgent | CZ | FLUENT | 1 | January 3, 2009 11:36 |
Oscillatory mesh motion setup mesh flux ERROR | jaswi | OpenFOAM Running, Solving & CFD | 5 | August 23, 2007 05:41 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
dynamic mesh - structured or cooper mesh | Manoj Kumar | FLUENT | 2 | November 11, 2005 02:18 |
How to convert STAR mesh into FLUENT mesh ? | Jihwan | Siemens | 8 | November 10, 2004 05:11 |
