March 15, 2009, 00:43 |
Initilization at subdomain
Hi, I would like to get some help about an lnitilization problem. Actually, the lnitilization in the cfx-pre is for global initilized condition for a domain. By the way, I want to give an initilized condition to a subdomain (not domain). For example, in the boundary details of a subdomain, we can give a fixed temperature as an option of the heat transfer. However, I want to give an initilized temp. instead of a fixed temperature in a submodain for a BC. Could you give me an answer for this? Thank you so much.
Jaho |
March 15, 2009, 23:39 |
Harshad
Rep Power: 17 |
Hi Jaho,
Specify that mesh you want to put in sub domain as another domain and put general connection interface in between the new domain and old domain. Then you can initialise as a temperature for all the volumes in that new domain. Then the boundaries temperature will be 'bounded' by that temperature so it will be like initialising for boundaries only. |
March 28, 2009, 14:53 |
Rep Power: 17 |
Hi Harshad,
Thank you for your reply and I am sorry for late answer. By the way, I wonder how to convert subdomain to domain. Because subdomain is 2D, it's not available to convert subdomain to domain (3D). If you don't mind, could you please explain about this a bit? Thank you so much. Jaho |
March 30, 2009, 00:58 |
Harshad
Rep Power: 17 |
I didn't understand when you said subdomain is 2d. Subdomain has to have a 3d mesh. I think boundary is 2d.
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
subdomain | kemdi01 | STAR-CCM+ | 0 | July 15, 2009 14:04 |
Subdomain or Interfaces (CHT) | sandeep_tu | CFX | 8 | July 14, 2009 11:06 |
set temperature on subdomain, in transient mode | nicolas | CFX | 0 | August 16, 2006 06:42 |
CFX-5.5: Meshing subdomain with inflation | Bogesz | CFX | 2 | February 15, 2002 04:27 |
