March 14, 2009, 10:04 |
Error : floating point exception; overflow.
Hello
I simulate a conjugate heat transfer model. I have received an error message from running cfx solver. Error: floating point exception; overflow. Do you have any idea about the cause of this problem? Thanks very much |
March 16, 2009, 18:44 |
james
Check the mesh to avoid zero volume cells.
May 18, 2010, 02:15 |
Abrie
Rep Power: 16 |
Hello, I had the same problem running k-epsilon and omega simulations in star-ccm+. When I refined the mesh to 5E6 cells I got the floating point exception error after 17-27 iterations. My initial pressure was set to 0, because I was working with low Re and pressures. When I changed my initial pressure to 8 Pa and my turbulence from length scale to k- epsilon everything went smooth again. I am simulating flow over a packed bed of spheres.
Regards |
May 18, 2010, 08:44 |
Rep Power: 144 |
Umm, right. As has been mentioned many times in this forum floating point exception simply means the linear solver has diverged big-time. This cna be caused by many things, either a unphysical setup or inadequate numerical stability being the main ones. You have to do something to increase the numerical stability of the simulation.
ERROR: Floating point exception: Overflow | Elisabetta | CFX | 23 | July 14, 2018 07:57 |
the problem of my transient simulation "Floating point exception: Overflow " | alloveyou | CFX | 15 | November 22, 2012 12:14 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 05:59 |
Floating point exception: Overflow? | mike | CFX | 4 | December 15, 2009 18:30 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 03:27 |
