HVAC Simulation
Old   March 10, 2009, 18:57
Default HVAC Simulation
David
I have successfully set up and run a simulation similar to tutorial 17 in CFX. The simulation is a room with air inlets and outlets, but no internal heat generation. I want to place cylinders inside of the room space and give them a heat flux value to simulate people in the room.
I have imported a separate mesh of 28 cylinders, each 5 feet high with 2 foot diameter, and place it inside of the room. I place the cylinders in a subdomain with a radiation source associated with the subdomain. Also I defined the cylinders with the boundary conditions of a wall with a set temperature of 90 degrees.
When I run the simulation I get a "Isolated fluid regions" error. It remarks that the isolated regions do not have the pressure level set. Possibly because the domain interface was not properly defined.
Any advice on how to set up the simulation better or to fix my error would be greatly appreciated. Thanks and have a great day.
Old   March 10, 2009, 23:36
Default Re: HVAC Simulation
Rikio
David,
The cylinders should be set as solid domain, not subdomain of fluid. I think this can fix your problem.
Rikio
Old   March 11, 2009, 16:46
David
Thank you very much. This seems to have solver the problem.
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 11:44
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 09:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 19:57
HVAC Simulation. Urgent !! Boris FLUENT 5 October 25, 2009 11:21
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 14:02
