question from ICEM beginner
Old   March 6, 2009, 18:47
Default question from ICEM beginner
Jiuan
I used Gambit before. For a 2D problem in gambit, I usually created several surface and then mesh them one by one. Right now, I have to switch to ICEM. I don't even know what is the basic procedure to mesh in ICEM. For example, if a step file is imported into ICEM, there are only points and curves. Should I create surface first as what I have done in Gambit? then mesh the surface? My current task is urgent. Please help. Thanks in advance.
Old   March 6, 2009, 19:41
Default Re: question from ICEM beginner
Hao
You can create block or surface. My suggestion is following the tutorials. The first tutorial is to build a typical 2D grid. It is clearly demonstrated.
[ICEM] Complete beginner with ICEM dfitz1000 ANSYS Meshing & Geometry 6 January 17, 2011 17:22
ICEM --- question about repair geometry zhaohui ANSYS Meshing & Geometry 1 April 21, 2010 19:54
ICEM -CFX a basic question Al Mazdeh CFX 2 April 5, 2008 12:51
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 04:39
Question from a beginner Arun K Main CFD Forum 4 August 13, 2004 08:17
